rolla_fxgt wrote:I'm just pee'd off its so ugly looking, reminds me of a shrunken svx, and perhaps a bit of the last celica
postfach wrote:The replacement for the AE86 was the AE92.
This is a new car.
Dragger_Dan wrote:
That doesn't look too bad tho
As soon as I see that I think - new celica and honda mashed together
BZG|Bling wrote:I think celica / austin martin
Lith wrote:I guess if you want to make B16A power and torque from a 2litre which uses more fuel than a JZA80.
Snoozin wrote:Aston Martin.
Heathens.
Dell'Orto wrote:Lith wrote:I guess if you want to make B16A power and torque from a 2litre which uses more fuel than a JZA80.
I know B16A's are pretty gutless, but geez, they arent that bad!
The Test Mule
The test mule is actually still very early in it’s development and in its experimental stage being based on a shortened Subaru Legacy chassis and running a SOHC 2.0L flat-four engine. Best Car isn’t aware of any wheelbase measurements at this time, but going by reports the test mule chassis is around 200mm shorter than it’s Legacy donor platform. The Legacy underpinnings are for experimental purposes only as the new Toyota Lightweight Sports Car will actually be based on a shortened Impreza 15S platform which is better suited to a smaller 1.5 - 2.0L (flat-four) engine and has ‘rear wheel drive friendly’ double wishbone rear suspension. The test mule is in very early stages with the car running the aforementioned 2.0L SOHC engine and a 4WD driveline (without front drive shafts) so it isn’t undergoing any serious performance driving tests at this point in time. Apparently Toyota has the ability to have this new lightweight sports car ready and on the market by the end of next year… if only they were so inclined. Instead, a lot of effort is being put into getting the most performance while keeping the retail price below 2,000,000 yen.
Why a 1.5L engine?
Price seems to be the limiting factor regarding the type of engine, and therefore total weight, of the Toyota Lightweight Sports Car. Best Car has been told that if a larger 2.0L engine were to be used, the cost of the car would definitely rise above the 2,000,000 yen limit and would then not live up to its ‘Entry Level Sports Car’ namesake. Also the rear differential sourced from Subaru (from the Impreza 15S) has been cited as a weak link, it being limited to engines of 2.0L capacity or under for reliability concerns. The 1.5L engine - named ‘EL15′ - is a DOHC flat-four powerplant and is also noted for producing less emissions than it’s larger SOHC sibling which is another important criteria that Toyota is trying to address. The EL15 only puts out 110ps @ 6,400rpm and 14.7kg/m @ 3,200rpm so Toyota is doing its best to lighten the chassis and body as much as possible in order to give the car a reasonable amount of performance. Just how much weight can be shed? Toyota is aiming for 1100kg and no more… this is another reason why the 2.0L engine was rejected as the larger engine would dictate a heavier chassis which in turn would exceed the 1100kg (total vehicle) weight limit by 100kg or more, even with considerable weight reduction. Only so much weight can be shed, and only so much can be done to keep the Lightweight Sports Car within the 2,000,000 yen limit so Toyota has a big job on its hands to address these issues and will certainly be an ongoing problem throughout the development cycle.
BZG|Bling wrote:postfach wrote:The replacement for the AE86 was the AE92.
This is a new car.
about time someone stated the obvious so all the dreamers out there can realise there will not be another ae86
Users browsing this forum: No registered users and 33 guests
