Rust Proofers
Rust Proofers
Postby soven » Thu Apr 17, 2008 4:19 pm
Anyone has experience dealing with professional rust proofers? Planning to rust proof the aw11 and deciding if I should go buy an air compressor and diy or let a rust proofer do it. I started wit fish oil in a spray can but I cant get to certain crucial areas. I rang a rust proofing place a wile ago and was quoted around $500 .
I recall some of them do offer a guarantee but not sure how that works really. Recommend me some reputable rust proofers or ones that I can trust.
soven
Postby xsspeed » Fri Apr 18, 2008 9:39 am
id be interested to find out how you get on mate, so far i've just been using fish oil as well.
Postby GTCRSHR » Fri Apr 18, 2008 12:22 pm
is it bare a metal shell ?
Nothing to see here ...
GTCRSHR
Postby Matty104 » Sat Apr 19, 2008 4:37 pm
i got some stuff for my ke from a paint supplier through work . ( linkup) its a converter and make the rust less reactive to stop it from spreading,
i cant recall the name but will find out for you tomorrow,
but basically you remove the loose scaley rust , (leave a small amount of surface rust so the converter has something to react and work with) and apply it, it goes on a creamy colour and turns black when it is dry , it is also a primer so you can give it a light sand and put a top coat straight over it , and works great , ( i was always prone to putting a pa10 over top of it just to be safe)
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby rusty85 » Sun Apr 20, 2008 11:24 am
i use some rust treatment from loctite, the guy i got my ae85 from gave it to me. basicly the same as what Matty104 has.. but its brush on and comes out in a creamy colour and turns a purpley black.. i also put zinc and primer overtop to be safe.. its worked good so far
rustspec 84 ae85 trueno
rusty85
Postby Bling » Sun Apr 20, 2008 11:35 am
they both sound like Kilroy(i think) its called, I used to use it when I worked as a painter at local freezing works. Seemed to do the trick.
Users browsing this forum: Google [Bot] and 41 guests
