Where to buy a AE101 Dash Light
Postby haydo » Sun Apr 20, 2008 7:24 pm
Hi guys.
One of my dash light bulbs blew today. It's the hand brake light. I swapped it around to make sure it was the bulb.
Took it into repco to get a replacement and apparently they don't sell them and sugested an auto sparky.
Where do I buy these bulbs from in CHCH if possible. :D.
The bulb appears to sit in a wee blue holder that screws into the back of the gauge cluster and doesn't seem to come out of the holder.
Thanks guys.
haydo
Postby Dell'Orto » Sun Apr 20, 2008 7:27 pm
Repco can get them, if its the size I'm thinking of. Just tell the numbnuts behind the counter to look in the Narva catalogue a bit closer.
Postby rallymazda » Sun Apr 20, 2008 7:28 pm
you can take it out the holder, just bend the 2 wires straight again,
but id recomend going to a wreakers and get one, probably no more than $5
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby Bling » Sun Apr 20, 2008 7:29 pm
the bulb should pull out no worries of that holder
local garage should have a replacement bulb
Postby AE82 FXGT » Sun Apr 20, 2008 10:45 pm
If it's the type I'm thinking of (the same type behind the heater controls)
You have to bend the wired connected to the bulb around the base of it and pull it out. I got mine from an auto sparky for like 30c a bulb
AE82 FXGT
Postby MrOizo » Sun Apr 20, 2008 11:06 pm
MrOizo
Toyspeed Legend
Postby GTCRSHR » Mon Apr 21, 2008 9:41 am
failing that i have a heap of them if you still cant get one
Nothing to see here ...
GTCRSHR
Postby pjay » Mon Apr 21, 2008 1:26 pm
Ahhhh. Repco do sell em, i replaced them all with flasher led ones. They are in the bulb section
pjay
Postby haydo » Mon Apr 21, 2008 1:44 pm
I might go down and there again.
Thanks for your help fellars :)
haydo
Postby neo » Mon Apr 21, 2008 5:19 pm
These days you even get the options, bulb, or holder, or bulb in the holder.. Just the numb nuts to look in the (blue section?) Narva catalog :)
neo
