I put 13 ltrs in my car this morning ; it is mixture of 90 % 98 fuel with 10 % bio ethanol, the pamphlet of full force 10 claims it is cleaner and burns more completely, contains anti corrosive additives so it is better for cars.
Sideros wrote: The report stated that cars prior to 2003 have fuel systems which might not be able to handle the corrosive properties of Ethanol and would form holes in fuel lines etc... In the united states I believe they use E3 and E5 (3%, 5%) which is fine on all cars however E10 isn't? Be wary is all I have too say and find out the facts from a reliable source before risking it. Saving $5 on a tank of gas isn't worth replacing the whole fuel system if all the rubber lines etc become perished is it?!
steve murch wrote:ive run this the 10% ethonal in karts and cars and when tuned to suit works bloody good,also done afew race cars on e85 which worked better than c16 and cheaper.
the toyota series run e85 but i dont believe its on pump yet, i run the e10 as such in my crap primera and no probs.
it doesnt make any power to start with unless its down hill with a 100mph wind behind it or over a cliff.
Adamal wrote:Basically, its like pump gas, but a much higher octane level. About 117.
Means that your engine can make more power with less chance of detonation. Advancing the timing or more boost as an example. Of course, that is if you've modified it to take advantage of the higher detonation level.
If your engine is completely stock, and made to run say 95, then C16 would be a waste.
Ethanol has a cooling property, which is another way of reducing the risk of detonation. This means it can be combined with a lower octane fuel, and wield a higher octane rating.
For example, Gull's Force 10 (90% petrol, 10% ethanol) is 95 octane fuel mixed with ethanol and rated at 98 octane.
Voodoo wrote:grantourismo wrote:the same .....![]()
with ethanol from Mt Maunganui
E10 over here in qld is usually cheaper than 91, mind u, we grow alot of sugercane
edit, although its not the 98 octance of gull 10
