Auckland Based Custom Welders/Metal workers please read!
Postby UZZ30 » Sat May 10, 2008 11:54 am
Hi Guys,
Im needing a few parts made up for my Soarer project in order to make it run, unfortunately the person I originally had lined up to do the work has proved to be useless! :X
Ive made up plans for most of the key parts which are easy to follow, needing them to be made of 6mm aluminum sheeting and some 3" 2mm thick tube.
Basically the parts I need to have fabricated is the intake manifold the supercharger sits on, effectively a rectangular box that sits on a 2JZ intake manifold with the top cut off. An adapter plate for the back of the s/c with 3" entry pipe, an adapter for the throttle body, some basic brackets for the T/B mount as well as intercooler and electric fan. Next key part is to join two cast pulleys together with bolts and spacers in order to get the exact belt line. The last part the tensioner mount which needs some 1" strong tube welded or bent into a shape with some mountings for it to bolt onto original spots near the power steering pump area.
If anyone in Auckland is interested in a Cash job or what ever and competent with this sorta fiddly custom work please give me a PM so we can discuss. Cheers.
UZZ30
