anyone got the hookups on PWR
Postby NOLAW » Sun May 11, 2008 11:35 am
hey im after a PWR W-A intercooler and iv been quoted 1590+gst for the lot...can anyone get it cheaper or is this as good as it gets?
NOLAW
Postby barryogen » Sun May 11, 2008 5:13 pm
might help if you gave a bit more info on type of car it's going in, part that you were quoted that price for, intended purpose.
I'm pretty sure that at least one of our sponsors are PWR agents, so maybe you should have a look through the sponsors section, and browse some websites.
From looking at this sort of thing a while ago, I got a decent "800HP" w2a IC from driven performance, that is doing a marvelous job in a Merc that a friend of mine has. It's a bit overkill(by about 500HP), but it's working fine.
barryogen
2ZZ Guru in training
Postby NOLAW » Sun May 11, 2008 6:32 pm
its going into a 1973 corolla, as you can imagine theres not really enough room for a front mount behind the grill and i dont want to go cutting anything up to make one fit which is why im thinking of going with one of these, part i was quoted for was the 300hp kit.
NOLAW
Postby Alex B » Sun May 11, 2008 7:12 pm
HRT has a front mount on his KE20 behind the grill, can get one to fit alright.
Postby NOLAW » Sun May 11, 2008 8:13 pm
what kind of i/c is he running?
NOLAW
Postby Alex B » Sun May 11, 2008 8:26 pm
400x350x75ish
Postby NOLAW » Sun May 11, 2008 8:29 pm
you sure he hasnt cut anything because from what iv measured youl be lucky to not cut anything out for an i/c with a thickness of 60mm
NOLAW
Postby Lloyd » Sun May 11, 2008 8:34 pm
Little bit cut, but bugger all. I'll try and get some pictures tomorrow for ya.
Postby NOLAW » Sun May 11, 2008 8:44 pm
sweet man that would be mint
NOLAW
Postby evil_si » Sun May 11, 2008 10:04 pm
you could always put it in front of the radiator, move the radiator back 75mm if there is enough room,
we did that in the ke30
evil_si
Postby NOLAW » Mon May 12, 2008 12:04 am
evil_si wrote:you could always put it in front of the radiator, move the radiator back 75mm if there is enough room,
yeah that was the plan until i got a 3 core ali radiator and gilmour pulleys, cant really move anything back now :roll:
NOLAW
Postby Lloyd » Mon May 12, 2008 6:35 pm
There is a bit of orange stuff (following along the front of the I/C only, nothing behind it), and a bit of silver stuff cut in the pictures. The orange section taken out is about half the thickness or less of the I/C and more was taken out of the silver bit than was needed by heaps. Am going to replace it if I ever get around to getting spare bits.
What are you putting in it? Even with the drive belt stuff on the front I've got heaps of room there. I can fit my hand open in between the radiator and I/C, there is about a 90-100mm gap in there, plus there is a fair bit of room from the radiator to the waterpump pulley.
Can see where the line of the silver bit goes in the bottom left compared with where the I/C sits
Nothing cut out of the bottom
Not the best pic but you can see how far back the intercooler goes compared with the silver strip.
Gap from I/C to intercooler
Gap between the pulley and the radiator
Postby samlloyd » Mon May 12, 2008 8:04 pm
Thats badass hrt
samlloyd
Postby l1ttle_d3vil » Mon May 12, 2008 11:18 pm
damn thats hidden nicely, slightly more discreet than mine :oops:
youve seen mine since it was setup aye morgan? nothing was cut for mine, except the inside of the wheel arches for the piping. the valance was already cut so i chose an i/c to suit, but if you got a thin one you could probably mount it same as mine without cutting anything/much. mines 76mm thick i think which is the "average" for those trademe i/c's - i have seen 50mm.
the size of mine is overkill for what i got at the moment so you could run something alot smaller...
Postby NOLAW » Mon May 12, 2008 11:58 pm
HRT wrote:What are you putting in it? Even with the drive belt stuff on the front I've got heaps of room there. I can fit my hand open in between the radiator and I/C, there is about a 90-100mm gap in there, plus there is a fair bit of room from the radiator to the waterpump pulley.
just running a 4age turbo, heres a old pic of my setup, radiators not mounted yet but gives you an idea of how far i can move it back if any (remember theres a fan on the back of the radiator, another reason i was thinking of going PWR water to air is that it would look mint with everything else in there and car would be a lot more stealth not being able to see any i/c but yeh i have trouble with multi choice decisions :lol:
NOLAW
Postby Lloyd » Tue May 13, 2008 12:19 am
You can still mount it like mine if you want, nothing behind the I/C is cut so you could sit the intercooler in place as you have everything on the pic above and not have to cut anything except those bits on the front.
As for getting intercooling piping through, the holes are already there for a KE20, problem is I think they are a little bit under 2 inch holes so they need opening up a little bit. You'd never know they'd been done unless you were super fussy on KE20s (or if you did a crap job opening the holes up).
You got heaps of room. And if it doesn't work, put a 5K in it :lol:
Postby Lloyd » Tue May 13, 2008 12:25 am
Cheers smithers, good to hear that sometimes :)
Postby NOLAW » Tue May 13, 2008 12:29 am
sweet then, cheers man will take all into mind. 8)
NOLAW
Postby Infinite » Tue May 13, 2008 8:43 pm
fuk dat looks nice
Lots
Infinite
Postby NOLAW » Tue May 13, 2008 10:31 pm
which one? :lol: :wink:
NOLAW
Users browsing this forum: Google [Bot] and 23 guests
