where to get 8mm spring washers?
Postby xsspeed » Mon May 12, 2008 2:13 pm
anyone know where to get 8mm spring washers?tried mitre 10 and repco yesterday, ended up getting some 5/16ths but they are obviously a bit big.
asked if they could get some in but the dude reckond the manufacturer (champion(?)) only did 6mm and 10mm in metric around that size.
Postby sergei » Mon May 12, 2008 2:46 pm
Any local bolt shop will do fine, or even engineering suppliers.
EDL
Blackwood/Paykel
Just look up fasteners in yellow pages.
Postby xsspeed » Mon May 12, 2008 2:50 pm
cheers sergei, so any place should be sweet, no preferred place thats both cheap and good quality? (i know i know cheap and good in the same sentence)
Postby Emperor » Mon May 12, 2008 4:30 pm
If you were in hamilton I could give you a handful free :lol:
Emperor
Postby xsspeed » Mon May 12, 2008 4:46 pm
lol yeah, i was surprised that the two places i went to didnt have them
Postby Emperor » Mon May 12, 2008 4:49 pm
We use them at work, get them from steel n tube.
Most places should have them tho, I got some from EDL (I think) not sol ong ago
Emperor
Postby Rick » Mon May 12, 2008 5:11 pm
How many are you after?
Postby xsspeed » Mon May 12, 2008 6:10 pm
just 6 for the clutch cover bolts
Postby Rick » Mon May 12, 2008 7:30 pm
Where are you in nz?
Re: where to get 8mm spring washers?
Postby Truenotch » Mon May 12, 2008 7:35 pm
xsspeed wrote:mitre10 and repco
:P two swears in one sentence :o ....
Your local steel and tube will be the go. I use Steel Masters here in Palmy.
Truenotch
Postby ee904age » Mon May 12, 2008 7:43 pm
xsspeed wrote:, ended up getting some 5/16ths but they are obviously a bit big.
5/16" is about 7.9mm, so if the are really 5/16 you shouldnt have a problem.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby xsspeed » Mon May 12, 2008 7:48 pm
Rick wrote:Where are you in nz?
Auckland, Mt Eden
ee904age wrote:5/16" is about 7.9mm, so if the are really 5/16 you shouldnt have a problem.
is it?, they seem quite big on the 8mm, will need to check, maybe they are 7/16ths
Postby Rick » Mon May 12, 2008 8:10 pm
I have 6 stainless spring washers if you happen to be out west auckland way..
Postby evil_si » Mon May 12, 2008 8:42 pm
7/16 is pretty much 11mm,
5/16 washers are generlly sweet on 8mm bolts
steel and tube
or if you feel like a venture to pakuranga im sure i can help you out
evil_si
