Good oil
Good oil
Postby method » Tue May 13, 2008 11:23 pm
Looking at some of castrols edge or what ever it is. The fully synthetic oil
some weights are MUCH cheaper than others, anyone know why?
Obviously oils with a wider range cost more to produce and are more prone to breaking down at high temp due to longer polymer chains etc etc etc, so require some tech manufacturing processes. But double the price?? Was quite surprised how cheap some of the weights are!
25-50 is $42
5-30 is $60
10-60 is $90
0-40 $90
I usually run a valvoline performance kinda oil 10-40 blend in my turbo 4age.
But if i can get a 25-50 for the same price that is fully synthetic maybe i should run that? Especially with the higher temps due to the turbo, i've had the whole exhaust housing red hot. Plus i've always wanted to try a slightly thicker oil in the car too.
PICS UPDATED DAILY
method
Postby Bazda » Tue May 13, 2008 11:38 pm
Pennzoil do a 25/50 in their GT racing range.
check out their website for the racing series oils.
Postby Lloyd » Tue May 13, 2008 11:53 pm
Why fully synthetic? More expensive doesn't make stuff better
As above, look at the Pennzoil stuff
Postby fuel » Tue May 13, 2008 11:56 pm
25-50 is for 'big bore' engines, ie dirty old pushrod V8s.. the viscosity range is quite narrow compared to the broad offerings from 0W40, 10W60 etc.
a thicker oil (thicker than it's meant to run on anyway) can put more load on the oil pump, and it can heat up the oil just that little bit more. On the other hand it does cushion the bearings better and provides quite good protection.
4A-GE, due to their compact multivalve 4 cylinder nature would probably be better suited to a 0-40 or 10W40 etc.
LOUD NOISES!!!
fuel
Postby method » Tue May 13, 2008 11:56 pm
What makes you say synthetic oils arn't any better?
I thought synthetic oils are more resistant to high temperatures and pressures/stresses and are less prone to break down than organic oils. Or whats what i thought.. Correct me if i'm wrong.
I know some people with high performance cars that swear by fully synthetic oils.
PICS UPDATED DAILY
method
Postby method » Tue May 13, 2008 11:57 pm
fuel wrote:25-50 is for 'big bore' engines, ie dirty old pushrod V8s.. the viscosity range is quite narrow compared to the broad offerings from 0W40, 10W60 etc.
Ahh sweet, exactly what i was after! Cheers for that.
PICS UPDATED DAILY
method
Postby escortman » Wed May 14, 2008 7:41 am
my engine builder told me never to run full synthetic oil even if its run it
4x4 toyota blizzard offroader
escortman
Postby fuel » Wed May 14, 2008 12:25 pm
theoretically synthetic oils are pretty good, but they don't allow an engine to bed in well. I made the mistake of using a semi-synthetic oil after 1500kms of running in my engine and now it's using a little oil, even though compression is still perfect and there is absolutely no blow-by.
I would probably wait until 5000~10000kms after a rebuild before using a synthetic oil.
LOUD NOISES!!!
fuel
Postby Bazda » Wed May 14, 2008 6:23 pm
If its just a road car then you wont need 25/50, if you using it for track heaps I would reccomend 25/50.
Postby method » Wed May 14, 2008 6:54 pm
Bazda wrote:If its just a road car then you wont need 25/50, if you using it for track heaps I would reccomend 25/50.
Why do you say that?
Its a road car, but only times it gets used aprox once a fortnight and every time it is used it gets a good cain. Thats what i built it for afterall. Can't afford to bring it to track that often but if i could it would be a "track car". Need to sort out the suspention on the rear end before i can call it a track car.
Engine is usually under quite a bit of stress. After a round around whenuapai/kumeu the manifold or even the whole exhaust housing is glowing red. It doesnt get hours of abuse end to end like a track car, just 30min or so at a time per outing.
PICS UPDATED DAILY
method
Postby escortman » Wed May 14, 2008 7:04 pm
i run pennzoil 15-40 mineral oil seems to be ok, only done 2000ks on the new motor though
escortman
Postby grantourismo » Tue May 20, 2008 11:33 pm
been using castrol oil for ages runs fine LOL :D
grantourismo
Postby 2jayzgte » Wed May 21, 2008 8:52 pm
If your going for Castrol Edge products I use ther RS 10-60 I reckon its real good oil,done the job in my car for about 5 years now good product.
2jayzgte
Postby IH8TEC » Wed May 21, 2008 11:34 pm
penzoil gt racing or whatever 20w/50
Users browsing this forum: No registered users and 54 guests
