Revtec, a very peculiar looking engine
Postby sergei » Fri Jun 27, 2008 5:09 pm
http://www.revetec.com/
The Directors are pleased to announce that the X4v2 petrol engine achieved a repeatable Brake Specific Fuel Consumption (BSFC) figure of 212g/(kW-h) or (38.6% engine efficiency) with a best figure of 207g/(kW-h) or (39.5%) at our requested target test of 2,000rpm with a BMEP load of 450kpa (approximately 75% load) and an air/fuel ratio of 15.2:1 using 98 RON petrol and a 10:1 compression ratio. We also achieved a BSFC figure under the same rev and load conditions using an air/fuel ratio of 14.5:1 of 238g/(kW-h) or (34.4%)...
The biggest "flaw" I can see with this engine is that roller bearing take full torque of the compression stroke.
Can they take that sort of load/jerk?
Very interesting concept, can be used (and I think it is used hence high efficiency claim) to change the piston speed depending what part of the combustion the stroke is...
Postby xsspeed » Fri Jun 27, 2008 5:44 pm
Was about to say it looks a bit like the old propellor aviation motors, then saw on their site thats what the initial design was for.
I see your point re: the bearings, I assume they would be rod bearings?
Postby bbq1988 » Fri Jun 27, 2008 5:51 pm
Ohh shineys... reminds me of a boxer crossed with a rotary :?
Baked, Not Fried.
bbq1988
Postby sergei » Fri Jun 27, 2008 5:52 pm
xsspeed wrote:Was about to say it looks a bit like the old propellor aviation motors, then saw on their site thats what the initial design was for.
Yeah, "rod" bearing, well plate in this case....
Postby xsspeed » Fri Jun 27, 2008 5:54 pm
I think roller bearing is what I meant (as opposed to ball bearing)
What do the twin camshafts at the top of the engine operate?
Postby sergei » Fri Jun 27, 2008 5:56 pm
It looks like they operate dynamo...
Postby xsspeed » Fri Jun 27, 2008 6:01 pm
I wonder how reliable the engine is, a lot of rotating parts!
Postby Lloyd » Fri Jun 27, 2008 6:36 pm
Postby touge rolla » Fri Jun 27, 2008 8:47 pm
a disturbing lack of valves, I thought mankind was past this pushrod nonsense
touge rolla
Postby method » Fri Jun 27, 2008 9:18 pm
pushrods are the future!
Would have too many belts if it trued using overhead cams
PICS UPDATED DAILY
method
Postby KinLoud » Fri Jun 27, 2008 10:13 pm
looks like the old orbital engine that high claims were made about...
Postby Mr Revhead » Fri Jun 27, 2008 11:03 pm
ah that sarich thing....... i wonder what happened to him?
Postby Adamal » Fri Jun 27, 2008 11:20 pm
method wrote:pushrods are the future!
Nahh mate, you'd just use a Subaru one!
Interesting concept... I'd like to see one in action.
Postby method » Sat Jun 28, 2008 4:23 pm
Subarus have too many belts as is, this would have twice the ammount of belts as a subaru.
dont see the problem with pushrods like that, it still uses a cam to move it. Just has a few extra components that may break...
PICS UPDATED DAILY
method
Postby Mr Revhead » Sat Jun 28, 2008 4:31 pm
that engine is more a proof of concept rather than a full production version
so pushrods cheap and easy to make/setup for what is probably an underfunded team.
if $$ was no object, then they would use an magnetic/pneumatic system or similar and have no belts or cams etc
Postby method » Sat Jun 28, 2008 4:34 pm
Segri, thoughts on a hybred electric system with a efficent gas turbine that charges the battery rather than a standard petrol engine?
Just a random thought.
PICS UPDATED DAILY
method
Postby rollaholic » Sat Jun 28, 2008 6:07 pm
method wrote:Subarus have too many belts as is, this would have twice the ammount of belts as a subaru.
seems like an odd thing to say - subbies have one cambelt just like most other belt driven engines :P
as for pushrods... not really the best, extra sets of tolerances = less precise valve actuation, which means less efficient!
Postby Jdawg » Sat Jun 28, 2008 7:43 pm
They are looking at the aviation market so engine will only be revving to 2000-2500 rpm. Pushrod tech is cheap and reliableto design, build and maintain, esp in a motor with low revs.
Jdawg
Postby method » Sat Jun 28, 2008 7:57 pm
Your right, by too many i ment too long :lol:
But not longer than any V8 i supose..
PICS UPDATED DAILY
method
Postby sergei » Sun Jun 29, 2008 10:51 am
method wrote:Segri, thoughts on a hybred electric system with a efficent gas turbine that charges the battery rather than a standard petrol engine?
I had that idea a while ago, small APU unit of jet plane and nice AC motor...
