Where to get stiffer W Series gearbox mounts?
Postby Rick » Sun Jul 06, 2008 11:47 am
I am after a stiffer gearbox mount for my W55. Can you get aftermarket ones or do they have to be custom made?
Sorry for the rubbish picture:
Postby Jason T » Sun Jul 06, 2008 7:30 pm
Fill empty space with windscreen urethane let dry 24hrs
Enjoy stronger than stock mount
Buy urethane from windsreen install shop expect to pay $30-$50 for good stuff
Fixing Toyota's since '87
Jason T
Postby Bling » Sun Jul 06, 2008 7:45 pm
weld on a steel plate. movement is overrated :lol:
Postby RomanV » Sun Jul 06, 2008 8:00 pm
Can't get it certed that way unless engine is solid mounted also.
P.S. Any chance I could borrow your gbox mount for a looksie/test fit for a day Rick? :)
Postby deaf_rattle » Sun Jul 06, 2008 8:12 pm
RomanV wrote:Can't get it certed that way unless engine is solid mounted also.
i have got one here if needed..
Postby cat007 » Sun Jul 06, 2008 10:15 pm
Jason T wrote:Fill empty space with windscreen urethane let dry 24hrs
Wow that sounds crazy. That really works? : :?
Postby Jason T » Sun Jul 06, 2008 10:33 pm
Done on mount eating fwd's for years
Make the air space sold urethane then less movement
Ive seen this work on a broken fwd mount while waiting on new.
Jason T
Postby bluemaumau » Sun Jul 06, 2008 10:39 pm
ive done it tomine, hopefully it helps
Postby cat007 » Sun Jul 06, 2008 10:42 pm
ooooohhhhhh
Sorry, I thought you meant replace the old "rubber" and use window sealant for the whole thing. You mean the whole at the bottom, fill THAT area!
Oops - my mistake hah
Postby AE86less » Mon Jul 07, 2008 6:44 pm
cat007 wrote:Sorry, I thought you meant replace the old "rubber" and use window sealant for the whole thing. You mean the whole at the bottom, fill THAT area!
That's been done on the FWD torque mounts, never driven a car with it but it's meant to make a hell of a difference.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
