Micro Compressor - Dynamic power booster ???
Postby eskimo » Mon Jul 21, 2008 2:02 pm
Hi,
Any one ever seen one of these
http://www.oneshift.com/idb/view_item.p ... 78&bid=210
The car im looking at has one fitted, i was planning to bin it strait away(as it looks like a stupid gymic add on) just want to make sure its not gonna do anything as soon as i take it off
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby sergei » Mon Jul 21, 2008 2:41 pm
It is just a spring loaded bypass valve.
It was designed for big hungry carburated V8s to lean out mixture slightly.
Never worked, never will.
Just makes an air leak.
Postby cogent » Mon Jul 21, 2008 5:01 pm
looks about as legit as a warrant sticker on warwicks ke70.
cogent
Postby AE86less » Mon Jul 21, 2008 7:32 pm
cogent wrote:looks about as legit as a warrant sticker on warwicks ke70.
You have no idea what you're talking about mate!
That air is split in 27 ways! 8O
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby xsspeed » Mon Jul 21, 2008 8:19 pm
That beats Dupree's 7 kinds of smoke...by 20
Postby Dragger_Dan » Tue Jul 22, 2008 5:32 pm
Stage 3 Air Magnetism Process:
Subsequent to Stage 2 the air accumulated is pressurized to go through a cavity charged with Neodymium Magnet. In this final stage, the atoms in the air will break into 2 components; ION NEGATIVE and ION POSITIVE. This results in the mixture of Fuel and Molecule with separated IONs. This combustion mechanism achieves a far more SUPERIOR result.
WTF! 8O Their knowledge of science astounds me.
Dragger_Dan
Postby Trls250s » Tue Jul 22, 2008 7:14 pm
SUPERIOR!!!!! haha whats wrong with a turbo?
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby AE82 FXGT » Tue Jul 22, 2008 9:32 pm
Trls250s wrote:SUPERIOR!!!!! haha whats wrong with a turbo?
Are you kidding me? a turbo wouldn't split air 27 ways...
AE82 FXGT
Postby xsspeed » Tue Jul 22, 2008 9:42 pm
Or break it into Ions :roll:
Postby MAGN1T » Tue Jul 22, 2008 9:58 pm
sergei wrote:It is just a spring loaded bypass valve.
But if your big hungry V8 is cruising at 14 to 1 AFR and the device leans it out to 16 to 1 , then it WILL save fuel.
No point in being 100% negative.
No doubt there are compromises because every modification is a compromise.
Steev
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby sergei » Tue Jul 22, 2008 10:02 pm
Steev
Do you sell these?
Postby AE82 FXGT » Tue Jul 22, 2008 10:48 pm
hahahahaha at the above
AE82 FXGT
Postby sergei » Tue Jul 22, 2008 11:03 pm
Postby eskimo » Wed Jul 23, 2008 11:02 am
haha, well ill think ill bin it if i get the car, getting check done tomorrow. Cheers
eskimo
Postby MAGN1T » Wed Jul 23, 2008 12:54 pm
Steev
Do you sell these?
No, if I did I wouldn't make any money.
sergei wrote:http://www.fuelsaving.info/air_bleed.htm
Like most things on the net, it's not entirely correct.
Steve
MAGN1T
Postby sergei » Wed Jul 23, 2008 3:43 pm
Steev
Do you sell these?
Steve
Right, so you are implying that all of this is true:
The “Micro Compressor” is a performance part that can give your vehicle Increased Horse Power, Better Mileage, and Longer Engine Life without any negative effects to your vehicle engine.
Stage 1 The “Micro Compressor” will substantially absorb surrounded air drawn in, through the air filter. ( Refer to Figure A ).
Stage 2 Compression Mechanism:
The driven air will be split in 27 ways. It is then forced through the Air Separator and through the bottleneck point.
At this stage you might just believe in tooth fairies (or santa, you choose).
If you believe what they wrote, you are obviously scientifically ignorant person.
If you want further debate on this subject I will find you evidence other tests of this (and other "fuel saver" devices) that they do not work and basically are just SCAMS, and designed to milk the money from ignorant people.
Postby MAGN1T » Wed Jul 23, 2008 4:39 pm
sergei wrote:It was designed for big hungry carburated V8s to lean out mixture slightly.
I was just referring to your incorrect 100% negative comments.
Steve
MAGN1T
Postby Trls250s » Wed Jul 23, 2008 4:58 pm
This can only be resolved with a sudden death game of chicken, both drivers in there cars driving at each other.
1600cc of Awesome
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby fivebob » Wed Jul 23, 2008 5:01 pm
MAGN1T wrote:Like most things on the net, it's not entirely correct.
Care to point out where it is wrong and why???
More importantly could you point out what claims about this device are true, and why they are true???
Postby cogent » Wed Jul 23, 2008 5:20 pm
hey, guy, stop being negative.
8)
cogent
Users browsing this forum: Google [Bot] and 22 guests
