Strange Happenings In The Sump...
Postby l1ttle_d3vil » Mon Jul 21, 2008 8:02 pm
...Of A 4AGE:
Any idea what these would be?
Looks strangely like a piston ring, or a crank bearing.
I pulled a sump off a 16v 4age on the weekend and found them. It was a stock bluetop 4age, but running a t25 turbo. Engine ran mint until it was pulled out, apart from alot of smoke. No noises, knocks etc.
Luckily they're too big to fit through the sump pickup :lol:
Postby Bling » Mon Jul 21, 2008 8:05 pm
they are space fillers, used to raise the oil level a cheaper way than using actual oil. :lol:
but seriously that s**ts whack! 8O
Postby fivebob » Mon Jul 21, 2008 8:15 pm
Ring lands, compression rings and other bits of piston by the look of things.
Large chunks of aluminium at the top left and bottom right are ring lands, steel pieces are bits of compression ring.
Postby rollaholic » Mon Jul 21, 2008 8:39 pm
that was my first thought too, though its hard to really tell the scale.
pull the pistons out!
Postby l1ttle_d3vil » Mon Jul 21, 2008 9:01 pm
the bigger chucks on the lower left look alot softer, similar to alloy all mashed up.
the bigger piece just right of the centre is about the size of a 5c coin, and of solid material.
Couldn't find anything to put in for scale! Would piston rings even make their way to the sump? I would've thought they'd get stuck in the bores or something?
Postby fivebob » Mon Jul 21, 2008 9:25 pm
l1ttle_d3vil wrote: Would piston rings even make their way to the sump? I would've thought they'd get stuck in the bores or something?
They will make their way to the sump quite easily, especially if there are chunks of piston missing. :evil:
Postby Dell'Orto » Mon Jul 21, 2008 9:29 pm
Literally detonated to bits 8O
Postby rollaholic » Mon Jul 21, 2008 10:21 pm
go the 4age... i like how blowing smoke is the only symptom :P
Postby snwtoy » Mon Jul 21, 2008 10:28 pm
Wicked. Top left piece almost looks like a piece of rod. Defintely looks like piston chunks to me :D
"Only blowing a bit of smoke" ... where's that tui bilboard
snwtoy
Postby Trls250s » Mon Jul 21, 2008 10:56 pm
Toyotas are good, mate rooted his 3s (you will know him little devil) and his engine had a very slight tick. Pulled the crank out and his bearings are fuxed.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby rollas22 » Mon Jul 21, 2008 11:36 pm
Plenty of life left in it bud, good for another few 1000 kms yet! those small bits are over rated haha.
KE-Corolla's for life!!!
rollas22
Postby l1ttle_d3vil » Tue Jul 22, 2008 12:03 am
rollaholic wrote:go the 4age... i like how blowing smoke is the only symptom :P
It was!! Took the car on a 50km trip last time I drove it and it just blew smoke. Ran 7psi fine all the way to the limiter. No misses, flat spots, noises, bangs, nothing; just smoke!
Should be safe to say the smoke isn't from my turbo anyway :lol:
The engine is still complete, would be interesting to either a). put it back in and see how long it lasts or b). pull it to bits and see what happened. problem is, its not my engine :?
Trls250s - who's that you're talking about? Don't know off the top of my head :lol:
Just put a project thread up if anyway wants to have a gawk and comment:
viewtopic.php?t=67561
Postby touge rolla » Tue Jul 22, 2008 12:47 am
+1 for option A :D
But 7psi is a bit weak wind it up to 12 :twisted:
touge rolla
Postby soopachargen » Tue Jul 22, 2008 4:38 pm
get some of that smokey engine additive stuff and put that in :twisted:
When in doubt, down and out.
soopachargen
Postby 85AW20v » Tue Jul 22, 2008 11:05 pm
And when the additive doesn't work - get them to repair the engine under their guarantee!! :D :D
See ya
Simon
85 MR2 20v
85AW20v
Postby IH8TEC » Wed Jul 23, 2008 12:13 am
dont go option A, it will stuff your turbo eventually which is another cost.
but yeah looks like alot of detonation to me. been there done that :oops:
Users browsing this forum: No registered users and 22 guests
