AE85 rust
AE85 rust
Postby IKE86 » Wed Sep 03, 2008 2:15 pm
Ive found the inside my doors theres a bit of rust :cry: dont know wether its worth trying to fix beacuse its right at the bottom on the inside and really hard to get at and im not really into fixing rust as i dont really have a clue as to what im doing. so would it just be easier to get new doors?
Or any cheap panelbeaters in tga?
Not the best photos but i think youl understand whats going on
84 Trueno ae85:current
AE92 levin:past
IKE86
Postby xsspeed » Wed Sep 03, 2008 2:19 pm
photos would help a diagnosis. on my corolla 82 I just replaced doors from a donor car, but itd be a bit hard with the price of 85's and 86's
Postby IKE86 » Wed Sep 03, 2008 2:22 pm
Sweet will get some photos up soon
AE92 levin:past
IKE86
Postby IKE86 » Wed Sep 03, 2008 3:51 pm
photos up
AE92 levin:past
IKE86
Postby Bling » Wed Sep 03, 2008 3:53 pm
that last photo makes me cringe :? anything is fixable, but a "cheap" fix will not end up saving you anything.
I'd attack all the rust with a grinder with wire wheel etc and see how deep it goes
Postby IKE86 » Wed Sep 03, 2008 3:59 pm
Its a sad sight i know :cry:
Its a really difficult place to get to but i will give it a go.
AE92 levin:past
IKE86
Postby xsspeed » Wed Sep 03, 2008 4:00 pm
obviously water has pooled at some point, is it your daily? might wanna check your rubbers.
if its your daily and you need it done quick I would say get it looked at by a panel beater.
If its a project car, try find a wire brush that fits to the end of a power drill that will be able to get right into the door skin. Then I'd wire brush that sucker to see how far the rust goes through.
Following that rust dissolver (a lot of it), sand, dissolver again spray it with fishoil, wipe it down, prime and paint.
If you have full penetration rust you will either be looking at getting plates welded = $, or getting new doors = $
Would be worth getting a quote before you shell out for new doors though
Postby IKE86 » Wed Sep 03, 2008 4:07 pm
Not my daily atm but was planning to get rid of my daily fairly soon spose that will have to wait. man its gonna be a mish to get anything down there.
ill give that a go and hope it hasnt gone through. will it be easier to just pull the door off?
And yea it is the rubber on the window has popped right out leaving a huge gap :evil:
AE92 levin:past
IKE86
Postby xsspeed » Wed Sep 03, 2008 4:26 pm
Gutted, yeah could be a mish getting in there. A worthwhile mod could be to slot or drill some points in the bottom of the door. That way it wont act like a bucket.
See what you can do with the door still attached, it might give you a better anchor when grinding the rust off than having it just propped up on something. If you need the door to go wider just pop the door stopper thing out.
Postby Looonie » Wed Sep 03, 2008 6:32 pm
If I remember correctly, there was a guy on Trademe selling fibreglass doors... and they weren't too badly priced...
Perhaps look into this option?
Otherwise, yeah as everyones said... need to strip it back to see how bad it is, if theres enough clean solid metal to work with of if its plate welding time...
Strip the entire door down and get it dipped then repaired, primed and painted.
Or on the cheap, wire wheel + bog + spray cans.
Rumple dee pumple dee doo...
Looonie
Postby IKE86 » Wed Sep 03, 2008 7:54 pm
cheers for all the advice guys will give it a good go this weekend.
AE92 levin:past
IKE86
Postby Trls250s » Wed Sep 03, 2008 7:58 pm
2 cans of fish oil and rust kill, one for each door. Treat it now and u will get about 3 months out of it before u should start to see a reappearance.
By then u should have saved enough cash to get it repaired.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby rollaholic » Wed Sep 03, 2008 9:04 pm
new doors arent crazy money considering everything else off the damn things seems to be worth its weight in gold.
paid $150 for a drivers door in mint nick from tama autos
fibreglass doors alot of hassle for a streeter, as they are just skins - no winding windows etc
Postby IKE86 » Wed Sep 03, 2008 9:30 pm
Well if anyone has a passenger side door flick me a pm. had a look at the drivers door and its sweet so ive put it down to the rubber on the passengers side :(
AE92 levin:past
IKE86
Postby xsspeed » Thu Sep 04, 2008 9:57 am
Seems on GD someone could put you in contact with a guy who is wrecking a ae85 that got written off.
edit: url might help:
http://garagedori.com/forum/viewtopic.php?f=1&t=5105
Postby IKE86 » Thu Sep 04, 2008 6:13 pm
Did a bit of work on it today and its not as bad as it looks it doesnt go through any of the metal :D so shouldnt be as big of a job as i thought.
Cheers for all your help guys
AE92 levin:past
IKE86
Postby 2LTR Rona » Thu Sep 04, 2008 6:35 pm
just a thought, have you traced where the moisture is getting in?
better to solve it fully now :)
2002 Altezza, 1974 KE25
2LTR Rona
Postby Bling » Thu Sep 04, 2008 7:56 pm
IKE86 wrote: ive put it down to the rubber on the passengers side :(
Users browsing this forum: Bing [Bot] and 25 guests
