neo wrote:Nope
You must have harnesses if you have a full cage, half cage you can use the factory lapbelt I belive.
Id install the eyelets for the harnesses and just put them in when required.
I didnt think you could get a cert for cages.. well I couldnt anyhow.
rolla_fxgt wrote:pretty sure you have to have them tied back when not competing, but someone will confirm that
neo wrote:Nope
summin wrote:As far as I know you can have full cage and harness, but needs to be homologated, you need an authority card...
From memory you also need to prove you do a certain number of trackdays/events to keep your card?
rollaholic wrote:so a half cage is warrantable with no cert required?
2jayzgte wrote:I don't have a cage at all but still use a harness for track days is this legal or not because I've done at 20 track-days with this current set-up and have'nt been pulled up once????
Zak wrote:My harness is certed, but I have no cage, and I can't use the harness on the road. So I don't really know what the point of it being certed is, but oh well.
Leon wrote:
It is acceptable to use a harness at MotorSport events without roll protection.
matt dunn wrote:Are you allowed full harness belts at a motorsport event
when used with a normal seat with a headrest,
rather than a seat with the holes fro the belts to come through?
Users browsing this forum: Bing [Bot] and 25 guests
