1MZ-FE... Are they worth touching?
Postby UZZ30 » Fri Sep 19, 2008 10:40 pm
Hi guys,
I've noticed the 1MZ-FE 3.0L V6 motors around in VVTI and non VVTI versions... After looking at some specs on the internet they don't sound too bad and apparently share similarities with the 1UZ-FE - but I could be wrong!
I'm asking as a mate of mine is looking to do an engine conversion in a ute of his, but wants an alternative to a 1UZ-FE/2JZ-GE or other motors so I was wondering if a 1MZ-FE would be worth bothering with..... like having one custom fitted to a W58 gearbox or whatever?
Any input would be great.
Cheers.
UZZ30
Postby RomanV » Fri Sep 19, 2008 10:44 pm
Pretty sure they mount up to 3S/5S bellhousings, hence why they're a popularish choice for the MR2.
Since you can get an 'S' bellhousing for a W55 etc, it could possibly be pretty straight foward in terms of mounting it up to a rwd gearbox.
However wouldnt pick one over a 1UZ, for any reason that springs to mind though.
Postby Timmo » Tue Sep 23, 2008 4:12 pm
hmm well presumably it would mean some customisation of the intake and exhaust due to them being setup for FWD applications. There may be other 'packaging' issues as well...which im sure you will run into with the 1uz as well but at least the end result is cooler :)
1uzs arent that expensive either?
Lightweight baby
1991 MX5 Supercharged
Timmo
Postby rollaholic » Tue Sep 23, 2008 6:43 pm
VQ35 or similar for the 6 cylinder win
Postby strx7 » Tue Sep 23, 2008 9:05 pm
if he's got $$ then get a 1GR-FE out of a 2005+ hilux. gonna be paying around $4500 from a dismantler, they are a torque monster of an engine. big torque from 1000rpm thru to 6500rpm.
Postby Timmo » Wed Sep 24, 2008 6:21 pm
nah.....2GR-FSE out of a Crown athlete: 3.5 V6, 6 spd auto and putting out 232kw @ 6400 rpm, 377 nm at 4,800......a mixture of port and direct injection.
The Lexus equivalent puts out a bit less I think
It's besides the point I havent yet seen one on Kiwi roads but.....
Lightweight baby
Timmo
Postby Lith » Wed Sep 24, 2008 6:53 pm
VQ37HR - 245kw @ 7000rpm, mad vtecs :D
2007 Mazdaspeed Axela
Lith
Postby Dell'Orto » Wed Sep 24, 2008 7:11 pm
6 cylinders are for girls, get a 3UR-FE, only $90K odd from your local Toyota dealer, and 283kw/543NM out of the box 8)
Postby Timmo » Thu Sep 25, 2008 2:15 pm
pah, nah V8s are for bogans ;) What he really wants is a 1GZ-FE V12 haha
Lightweight baby
Timmo
Postby Lith » Thu Sep 25, 2008 2:46 pm
Its going in a ute, so bogan is the theme, no?
Lith
Postby Snoozin » Thu Sep 25, 2008 3:08 pm
Turbo a 3RZ and slam that in there.
If it's a Nissan ute, then a turbo TD42. Then proceed to tow small towns.
Snoozin
Users browsing this forum: No registered users and 29 guests
