brake pad recommendations (hilux calipers)
Postby l1ttle_d3vil » Mon Oct 13, 2008 6:53 pm
I need some better pads for my front hilux calipers on the rolla. I assume the ones on there are the moment are standard ones, but the back is wanting to lock up before the front.
the calipers i'm using are off a 79 - 88 4WD Hilux and have the staggered piston size.
are there any good brands to go for, anything to avoid etc etc?
thanks
-matt
Postby mjrstar » Mon Oct 13, 2008 8:01 pm
I could not find any decent uprated pads designed specifically for the hilux caliper... but...
endless CCX pads designed for a s4 rx7 will fit the old style hilux 4 pots... , they needed a small amout of modification to fit ie: bench grinder, i am out of the country so can't help with a part number sorry. these are not cheap but work REALLY well. Mintex or ebc would probably be cheaper alternatives also to fit the series 4 rx7.
If you were using the bigger hilux newer calipers with the fins on them you need a pad from a wrx 4 pot (around 99 model I believe).
Have a look at my starlet in the project section there is a pic of the brakes to see if they are the same type of caliper.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby l1ttle_d3vil » Tue Oct 14, 2008 9:36 am
yeah im using the same calipers as what you've got.
I did have the newer calipers with the fins but they crapped out so got another set of "hilux calipers" off trademe and they turned out to be the older style.
would you have access to model numbers when you're back in the country? any more info you can send would be a huge help!
are the pads off any s4 rx7, or only specific years?
-matt
Postby mjrstar » Tue Oct 14, 2008 9:53 am
i'm pretty sure i still have the box for the pads in my garage but that won't help you for about a month...
i'm not too sure on wether there is any differences in the years of s4 rx7's sorry. any decent brake shop should be able to help you out with that info...
i got mine through eugene at tradeparts, wairau road in glenfield. calling him may solve your issues.. (so long as you get him on a good day)
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
Postby MikeMan » Wed Oct 15, 2008 1:43 am
Depending on how much you want to spend Race Brakes can make pads for anything.
Ship them your old pads and they will strip any remaining material and use the back plates as the basis of new pads.
MikeMan
Postby Mr Revhead » Wed Oct 15, 2008 6:09 pm
what are you using the car for?
if its a road car, or even just the odd track day id go with stock toyota pads
Postby l1ttle_d3vil » Wed Oct 15, 2008 7:14 pm
street car but will take it down the strip and the track when i get the chance.
it probably has stock toyota pads on there at the moment, but no idea how old/what cond they are. I did give them a roughen up with some sand paper but im sure there would be something better around.
Postby Mr Revhead » Wed Oct 15, 2008 10:12 pm
yes there will be something better, at greater cost.
but for your use stock ones more than ok
think how heavy a hilux is compared to your corolla.
if you can find a friendly toyota parts department go look at all the pads of the right shape (theres often 4-5 compounds of the same shape) and choose the ones with the highest metal content. you can clearly see it in the pads.
Users browsing this forum: No registered users and 32 guests
