Recommend Auto sparky in Manukau?
Postby Lanius » Thu Jan 15, 2009 4:39 pm
Someone suggested a brilliant paint and panel place in Manukau for me not long ago, and I'm hoping someone can recommend a decent auto sparky too. Did a search, but couldn't quite find what I was looking for.
Relatively simple job for someone who knows what they're looking for I guess (horn keeps blowing the 10 amp fuse in the engine bay), but I'm no good with auto electrics >_<
Any recommendations?
TIA
Lanius
Postby Jason T » Thu Jan 15, 2009 4:49 pm
Papatoetoe Auto Electrical
Tui Street
Papatoetoe
Ph 278 8147
http://www.finda.co.nz/business/listing/1k12/papatoetoe-auto-electrical-ltd/
Fixing Toyota's since '87
Jason T
Postby GTCRSHR » Thu Jan 15, 2009 4:50 pm
aftermarket steering wheel ?
Nothing to see here ...
GTCRSHR
Postby Lanius » Thu Jan 15, 2009 5:09 pm
Jason T wrote:Papatoetoe Auto Electrical
Tui Street
Papatoetoe
Ph 278 8147
Thanks, have been pointed toward another place closer to home, so will try them first, and use PAE as a back up :)
GTCRSHR wrote:aftermarket steering wheel ?
Yes. The problem started about 3 months after installing the wheel, was fine up til then. Have already tried a new boss kit (after two and a half hours driving backwards and forwards between various Repco branches, having been given the wrong boss kit THREE times :evil:), no difference to the problem though :?
(This of course, also means I now have a spare boss kit for sale.)
Lanius
Postby GTCRSHR » Fri Jan 16, 2009 9:05 am
does it blow when you press the horn ?
GTCRSHR
Postby Lanius » Fri Jan 16, 2009 9:38 am
Yes, and have just discovered that its the actual horn(s) that are at fault. The previous idiots I took it to told me that they tested the horns, so I ruled them out and didn't even bother disconnecting them to test :evil:
Avoid "MA Auto and Electrical" in Manurewa (just south of Southmall on Grt Sth Rd) like the plague :? Left a bloody big oil stain foot print on my driver's floor mat, only did a wheel alignment when I told them it was "wobbling" at 100kph, and ASKED them to do a balance as well. I had booked in with them for a 10am drop off, didn't hear back all day, arrived at their workshop around 15:00 to discover they hadn't even started working on the car yet :evil:
Only bonus is they do a WOF for $20.
Lanius
Postby GTCRSHR » Fri Jan 16, 2009 11:01 am
so sorted out now ?
GTCRSHR
Postby Lanius » Fri Jan 16, 2009 12:43 pm
GTCRSHR wrote:so sorted out now ?
Yep, all working now thanks :)
Lanius
Postby BlakJak » Sun Jan 18, 2009 9:20 am
Lanius wrote:Yes, and have just discovered that its the actual horn(s) that are at fault. The previous idiots I took it to told me that they tested the horns, so I ruled them out and didn't even bother disconnecting them to test :evil:
Thats no bonus!! I really struggle to find auto places that do a good job.
Last place I had WOF and some minor work done frustrated me no end; they passed my WOF and didnt notice that my brake rotors (all 4) were below minimums?!
BlakJak
Postby rollaholic » Sun Jan 18, 2009 9:23 am
you cant really expect your brake rotors to be measured at wof time - not for $40. thats part of servicing... as long as the brakes arent obviously damaged and perform to the required standard, thats good enough.
Postby BlakJak » Sun Jan 18, 2009 9:50 am
Oh, ok then, how bout rear brake _pads_ below minimums as well? To the point they were squeaking under brakes?
BlakJak
Postby Alex B » Sun Jan 18, 2009 11:49 am
You might want to look up the WOF manual on that. Pretty sure pads are not a wof item, or you cant take the wheel off to check them or something stupid to that effect.
Postby BlakJak » Sun Jan 18, 2009 12:33 pm
yah but shouldnt you at least note the squeaky noise on the wof sheet if its observed?
Previously WOF agents have noted things likely to come up like brakes, perhaps I just assume too much.
Anyway, enough of a thread hijack..
BlakJak
