Angle grinder Discs
Angle grinder Discs
Postby xsspeed » Sat Feb 14, 2009 7:15 pm
What thickness angle grinder discs should I use to cut through some panels? I have like 5mm or something but thats stupidly thick for what i need, how thin should I go?
I think it takes a 150mm diameter disc
Postby Stu- » Sat Feb 14, 2009 7:16 pm
Thinner the better for cutting, if your grinding back use the big fat ones
Project Thread
Stu-
Postby xsspeed » Sat Feb 14, 2009 7:25 pm
Yeah cutting, but the cutting discs I have are too thick for what I want to do. Wheres the best place to buy? Local hardware shop? Its nothing super, just cutting the rear taillight frame from a corolla liftback and the cambeelt engine mount side.
Any brands of discs better than others etc?
Postby Bling » Sat Feb 14, 2009 7:29 pm
Yeah most local hardware shops should be able to sort you out with a 2mm disc or similar.
Most brands will probably be ok just make sure you have good safety equipment as it only takes a second to do permanent damage with one of those :? Just don't go for $2 shop ones :lol:
Postby xsspeed » Sat Feb 14, 2009 7:31 pm
Yeah thats what I was gunna get at, re kickback etc, if any brands/disc materials are prone to it. Don't wanna wear in the face/hand/leg/anywhere etc lol
Postby flygt4 » Sat Feb 14, 2009 7:31 pm
don't cheap out on discs or use the wrong type of disc to grind/cut either. don't be tempted to try grind up the edge you just cut with a cutting disc. a lot of people don't realise they are prone to shattering if misused and tend to embed fragments in your legs etc. usually has quite a nasty result.
i'd say any old mitre10 would have what you are after.
flygt4
Postby xsspeed » Sat Feb 14, 2009 7:38 pm
sweet will pop up there in the morning. cheers guys
Postby jakesae101 » Sat Feb 14, 2009 7:51 pm
you can get real thin cutting ones that are farking good used to use them a bit back in my apprenticeship and when working on the car they werent cheap but real good bacause they were thinner than other cutting discs they cut quicker and didnt generate much heat when cutting they were flexovit ones thats right
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby Dell'Orto » Sat Feb 14, 2009 10:00 pm
We have flexovit ones, they're brilliant, like 1.5mm thick? They get eaten reasonably quickly, but they cut metal like no-ones business.
Postby thegreatestben » Sat Feb 14, 2009 10:08 pm
Norton ones that are for cutting stainless rule.
Esp. for cutting springs :lol:
thegreatestben
Postby narlystarly » Sun Feb 15, 2009 8:54 am
Yep as a couple guys have said, you can get 1mm thick metal cutting discs and they are the business for ripping through all sorts of steel quick as. Will chop springs as if they were plastic!
narlystarly
Postby evil_si » Sun Feb 15, 2009 6:50 pm
1mm disks are tops,
but have to be very careful using them,
have to cut sraight and not load the side of the disk or they blow,
apart from that they last for ages, cut like a hot knife thru butter less sparks, less heat more accurate
evil_si
Postby xsspeed » Sun Feb 15, 2009 6:54 pm
Yeah I got a couple of 1mm discs. Norton I think the brand is. From Mitre 10
Postby FLAWLES » Sun Feb 15, 2009 6:57 pm
1mm tits
best for cutting most things
our engineer at work loves them
FLAWLES
Postby QikStarlie » Sun Feb 15, 2009 7:17 pm
thin ones are mean. the normal thickness cutting discs are hopeless after using them.
QikStarlie
Postby Stott69 » Sun Feb 15, 2009 10:42 pm
Iuse both 1.6 and 1mm ones at work. the life of the disc tends to vary depending on thickness of disc and how hard you push it through the material
Image jzs147 Aristo money pit
Stott69
Postby tsoob » Mon Feb 16, 2009 8:15 pm
Dell'Orto wrote:We have flexovit ones, they're brilliant, like 1.5mm thick? They get eaten reasonably quickly, but they cut metal like no-ones business.
they are the shit, work really good on springs so im told HAHA
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby crispy'86 » Mon Feb 16, 2009 9:09 pm
1mm discs are really good for cutting through 5mm steel. I got given a couple to try and it made a huge difference from the 2mm thick blades i was using. Alot faster cutting through the material, although of course, i think it'd eat up alot more discs using thicker ones. Always a compromise
crispy'86
Postby neo » Mon Feb 16, 2009 11:23 pm
The 1mm ones are great if the metal is thin, or your cutting along an edge instead of across it
neo
