Sway bar makers
Sway bar makers
Postby fxgt race » Sun Mar 22, 2009 7:06 pm
Does anybody know if there is a crowd in nz that makes sway bars to any specs,Im after a bigger one for the rear of my ae82 fxgt than the 18mm whiteline rear sway bar i have at the moment.
fxgt race
Postby Bazda » Sun Mar 22, 2009 8:24 pm
Snells Springs
Amazed you need a bigger sway bar for the rear.
Sounds like you need to work on the fronts, possibly harder springs...
whats your setup now anyway?
I still run the standard bar on the rear, tried a whiteline one but got mega oversteer.
Postby Distrb » Sun Mar 22, 2009 9:33 pm
whiteline do a 20mm solid rear as well. (i run it on mine)
unless you need to go larger than that?
Distrb
Regular Poster
setup
Postby fxgt race » Sun Mar 22, 2009 10:26 pm
I run 500lb up front ,600lb back,3.4deg camber up front,2.5deg backs,set my car up with string lines with 4mm over the rim each side up front toe out.The car is handling good just want it to sit even flatter on corners.Just had it dynoed at 122kw atw,looking at a 1.45 at taupo and getting into the 1.09 around puke.current at 1.46.5 at taupo and 1.10.5 at puke.Don't want to go harder with springs as the car is down to 800kgs an is as stiff as.
fxgt race
Postby pc » Sun Mar 22, 2009 10:30 pm
I've got a whiteline adjustable on the hardest setting, it measures at about 18.3mm (must be the paint).
Car is neutral most of the time, more negative camber in the rear seemed to help after I changed to hard suspension.
Edit: just saw your post, your camber settings are about the same as mine, although I run with no toe.
8kg front, 6kg back, and car is around 890kg.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Mr Revhead » Sun Mar 22, 2009 11:05 pm
no toe at rest? you'll be getting a reasonable amount of toe in then
you could try altering the mounts of your current bar to make it stiffer, move them in a bit. doesnt take much to make it quite a bit stiffer
