upcoming NI drag meetings
Postby l1ttle_d3vil » Wed Apr 01, 2009 8:40 pm
Does anyone know of any drag meetings coming up at Meremere or Taupo?
Had a look on a few websites, but just wondering if anyone knows of any?
It would be my first time out, so the less competitive the better :lol:
Postby finx » Wed Apr 01, 2009 9:09 pm
winter speed would be you closest non competitive meets. they are still a couple of months away yet thou. these are normally the best to go to for 1st timers as you get loads of runs to practice as there isn't that many racers and its a lot less competitive.
failing that there will most probibly be some private days being organised by other forums or car groups you could try stick you nose into.
there's the outlaw drags on the 12th of April but that's a competitive meet with support brackets. but might not be the best meet go to if you car isn't overly fast and its your 1st time.
daily: ep71 turbo s 2et 90hp atw 15.5sec 0-400m (stock) current 5efhte + ct9b on 6psi, 13.7@158km , torque steer??
nothing sounds like a 2stroke engine on the rev limiter
finx
Postby cogent » Thu Apr 02, 2009 8:42 am
pro tip: get someone on the day to run you through how the lights work at the tree and staging and everything.
nothing worse than thinking you got it sorted and then all of a sudden the other dude is launching off outta there and you're still in neutral waiting for the 'get ready' signal.
cogent
Postby l1ttle_d3vil » Mon Apr 13, 2009 10:57 pm
mint sounds like winter drags would be a go, will give me time to sort out the little things.
have done a fair bit of reading but will get some advice on the day too :lol:
couple of other queries -
*do helmets have to meet a specific safety standard, no matter what meeting you're attending?
*radiator catch cans are mandatory, but would a plastic bottle cable tied down be sufficient or does it have to be something more flash? :lol: (doen't have catch can from factory)
Postby loose_unit » Mon Apr 13, 2009 11:16 pm
Yeh they check for a certain code on the tag of the helmet, though its not as hardout as msnz rules. As long as its a pretty modern helmet it will have the right code on it for drag racing.
As long as the catch can will stop water from leaking down onto the track then it will be acceptable.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby l1ttle_d3vil » Thu May 14, 2009 9:37 pm
Right, car is ready to go, at the moment. See if its still going in a months time :lol:
Codes on my helmet are ARC E13 050146/J-2005. Can't find any details about it on the net, but I got it from a motorcross shop a couple of years ago for trackdays etc. Should this be sweet??
Dates for winter dragwars are:
14/06/2009 - Winter Dragwars #1
28/06/2009 - Winter Dragwars #2
12/07/2009 - Winter Dragwars #3
26/07/2009 - Winter Dragwars #4
09/08/2009 - Winter Dragwars #5
30/08/2009 - Winter Dragwars #6
Postby loose_unit » Thu May 14, 2009 9:44 pm
My ones just a general motorbike one, heaps of people use motorcross ones. Cant remember the exact code but it will be fine. Its really old ones that generally dont have the right code on them.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
