brake lines
brake lines
Postby NOLAW » Tue May 12, 2009 7:01 pm
im not sure which section this is ment to be in but im looking for somewhere in the BOP that can help me out with instaling my brake/clutch line, if anyone knows someone or someplace they recommend, let me know :wink:
NOLAW
Postby l1ttle_d3vil » Tue May 12, 2009 8:32 pm
what brake lines are you wanting to replace? the factory steel tube ones?
and i assume you need a new clutch line set up? they're pretty easy, i've done them on mine. can get the gear required to do it if you want?
