Anyone with a noise meter?
Postby BZR4AGE » Wed May 27, 2009 12:14 pm
Anyone in Auckland got a noise meter handy?
Just want to measure the nosie of my exhaust to see if it exceeds 95dBA, as I want to go on the track on Pukekohe, but apparantly I cannot exceed that limit at any time.
BZR4AGE
Postby Jazza » Wed May 27, 2009 12:46 pm
2nded. Happy to have a few beers with whoever can lend it :P
1996 Curren - On Tardme
Jazza
Postby molex » Wed May 27, 2009 12:54 pm
Nobody cares at puke. If your car is able to be driven on the roads without EVERYBODY staring, it's quiet enough. Last time I went I had an empty 2.5 inch pipe off the turbo and you seriously couldn't hear my car in the pits. Had to check it was still idling every so often.
95dba is loud as hell
molex
Postby Py7h0n » Wed May 27, 2009 12:57 pm
Don't worry - Just go down to Puke and have fun :)
Py7h0n
Postby pjay » Wed May 27, 2009 1:14 pm
95 dB isnt loud as hell.
95 dB is:
* Music Practice Room
* Electric Drill
* Walkman at 5/10 (half volume)
* Heavy traffic
I'd imagine Hell is pretty loud. As its all heavy metal and tortured souls
pjay
Postby unstable » Wed May 27, 2009 2:36 pm
I have one hear at work. pop in and I'll test it for you.
The 95db at Puke is different to the test done for wof/cert because Puke is a passing test were as the WOF is a static test. Static test always read louder.
2000 JZX100 Chaser
13.827@167kph@ Nightspeed.
Owner- Pit Stop Grey Lynn. PM for Quotes.
unstable
Postby CelicaGT8 » Wed May 27, 2009 10:19 pm
They do care at puke, i would know, had a straight through exhaust on my 162. Couldnt run again unless i could reduce it.
I have a meter at work too if anyone is in papakura clevedon area and wanted to give it a shot.
But does anyone know the regulations on how to measure it, is it 3m back on a 45` angle?
CelicaGT8
Postby tsoob » Wed May 27, 2009 10:33 pm
molex wrote:Nobody cares at puke. If your car is able to be driven on the roads without EVERYBODY staring, it's quiet enough. Last time I went I had an empty 2.5 inch pipe off the turbo and you seriously couldn't hear my car in the pits. Had to check it was still idling every so often.
WRONG!! at the last d1 we had 75 complaints in the first hour.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby mjrstar » Wed May 27, 2009 11:12 pm
some nokia phones had a db meter which was quite accurate, they were an el cheapo phone too... might be worth looking in to.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby Emperor » Wed May 27, 2009 11:13 pm
Ive only been done in timaru and my rx7 was 96db for a few years
Emperor
Postby RomanV » Wed May 27, 2009 11:30 pm
tsoob wrote:WRONG!! at the last d1 we had 75 complaints in the first hour.
Yes, but IIRC it's the noise of screeching tires that was the point of annoyance with drift days.
Postby d1 mule » Wed May 27, 2009 11:38 pm
95 dB is $&#$% loud man therre is only 1 car in drift south that is that loud (got made to retire cuz was too loud 96dB) and it hurt your ears when it went past
d1 mule
Postby escortman » Thu May 28, 2009 7:47 am
mate took his r32 scummy and only had half an exhaust, only got told to stop cuz he was drifting
4x4 toyota blizzard offroader
escortman
Postby Jazza » Thu May 28, 2009 8:45 am
Point is, i dont wanna turn up after driving 45 minutes (Ok, fine 20 :lol: ) to get told i have to turn around. Dont have a silencer for it etc, nor a smaller tip.
Jazza
Postby Quirky » Thu May 28, 2009 11:05 am
N/A are abit louder than Turbo's though, if both were to have straight pipes.
The compressor acts as a muffler.
I put a straight through exhaust with one resonator on my old BZR and got 98dB, a tad too loud.
Hello There
Quirky
Postby strx7 » Thu May 28, 2009 11:34 am
all race tracks in NZ are 95 or 96 dba at 30 metres right angle under full load, that means if you are directly behind the car and its under full load, its FRIGGIN loud!!!!
Postby Oggie » Mon Jun 15, 2009 7:03 pm
strx7 wrote:all race tracks in NZ are 95 or 96 dba at 30 metres right angle under full load, that means if you are directly behind the car and its under full load, its FRIGGIN loud!!!!
lol funny thread..
I got my legnum knocked back twice for a warrent because of a loud exhaust system, How the measure it plays a huge part..
they rev it to 3k rpm and then 5k rpm. if it peaks over 95db youre failsauce.
My 1st atempt was 106db, only because the dumb ass measured the noise just inside a warehouse. and had the rear of the legnum poking towards the garage door.. and to make matters worse, there was a strong wind that we blowing the noise back into the garage.
106db due to the bad moron not knowing how to measure etc...
2nd atempt was 95db and i failed... some "new" law.. but looking back my 97 legnum passed on that one.
so i went to my family garage where i have gotten wofs for years, and he told me it only peaks over 95 when they button off from 5k rpm.
he passed it.
Oggie
Postby IH8TEC » Mon Jun 15, 2009 7:38 pm
actually 95db is not that loud at all.
I got a green sticker for my exhaust being too loud (silencer wasn't it, my bad) so put it in went for wof, he said it wasn't that loud but since it got green stickered for it. will pay to go get it tested.
So today i went in to LVV Certifier to get my exhaust tested. Silencer in, mic setup properly at right distance, engine at 4000rpm tested at 95.2db, now the very upper most limit for the static test is 95.4db, so i JUST scraped in.
$200 later i now have a completely legal exhaust, with sticker on the muffler and a sheet i have to keep in the car at all times, although the silencer HAS to be in for it to be legal on the road. But now a cop has no grounds to give me a ticket for it as long as silencer is in, and on the sheet it states that silencer must be fitted.
He was rather suprised that the lack of mufflers in passed, 2.5in dp into straight 3in with a cannon muffler and silencer :P without silencer it's 117db at 4k with no load
Apparently the static one (which i did) is more repeatable, and one i got tested with was $14,000 worth of kit. Apparently the warrant places that have them are only like $500 ones but their margin of error is alot, hence when a warrant place tests them they can't be louder than 93db,
So thats from my experience today at lunch time.
Oh, and my exhaust is certed, how many people on here have theirs done?
Postby Jazza » Mon Jun 15, 2009 8:55 pm
Will be getting it done once i can confirm the approx volume - if its near 93 - ill be attempting to make it quieter...
Jazza
Postby Rick » Mon Jun 15, 2009 9:41 pm
I tested mine the other day 93 db @ 4000rpm 500mm inline from the tip
4AGZE, One coby and rear muffler..
To me it didn't sound that loud at all, it was getting like 86 db at idle.
Users browsing this forum: Bing [Bot] and 11 guests
