Car Carpet Cleaning...
Postby HZRDIZ » Mon Aug 03, 2009 10:15 am
Some douche spilt a milkshake in my car on Friday, all through the passenger foot well.
We thought we got it all cleaned up and chucked some chemicals on there but over tee past couple of days, there is something still there cause the milk has gone off and the smell is gettign pretty nauseating and unbearable.
Any suggestions on getting rid of this smell? Does it involve getting the likes of a rug doctor or something to pull it out of the carpet?
Drinking 42 BELOW Passionfruit Vodka is like walking along the street and seeing this really hot girl and all you can think is "Man, I don't understand how anyone can be gay".
HZRDIZ
Postby no_8wire » Mon Aug 03, 2009 10:16 am
Tried boiling water + lots of towels?
That worked last time it happened to me.
no_8wire
Postby GTCRSHR » Mon Aug 03, 2009 11:02 am
steam cleaner,
valet ?
Nothing to see here ...
GTCRSHR
Postby xsspeed » Mon Aug 03, 2009 11:08 am
get toddy to do it at car fe
Postby Py7h0n » Mon Aug 03, 2009 11:11 am
RugDoctor!!
Py7h0n
Postby HZRDIZ » Mon Aug 03, 2009 11:18 am
Py7h0n wrote:RugDoctor!!
Hmmm just checked out the size of a rug doctor - i think that may be dificult gettign that thing to clean the small space in my car.
Hello friends who work for a carpet cleaning business!!!
HZRDIZ
Postby postfach » Mon Aug 03, 2009 11:45 am
Tried friend for carpets? Worked for me on something worse than milk. Took a few applications though...
postfach
Postby ~SlideWays~ » Mon Aug 03, 2009 11:47 am
They come with a hand held attachment :wink:
~SlideWays~
Postby 2LTR Rona » Mon Aug 03, 2009 11:55 am
If it was me doing it I would remove the carpet from the car, clean the passengers foot well to remove any possible residue that might have soaked through & give the carpets a really good shampoo or steam clean.
Nothing worse than going to all the trouble of cleaning the carpets in the car to only find there has been some seep through between the carpet & foot well
One trick we use to use in retail when fridges were returned & stank was placing a bowl with vanilla essence in it inside the fridge over night or for a couple of days after cleaning them, works a treat to remove smells that have seeped in to it, might also work for you
2002 Altezza, 1974 KE25
2LTR Rona
Postby HZRDIZ » Mon Aug 03, 2009 2:22 pm
Right, got deodorizer & air fresheners under the seat and shake & vac sitting on the carpet at the moment. Will give it a few treatments of that and hope that helps it.
On the plus side my car now does smell citrus-ey fresh :lol:
HZRDIZ
Postby Quirky » Mon Aug 03, 2009 3:16 pm
Boiling water works pretty well.
Steam is even better, it dilutes any milk residue.
I had a similar problem and I used the steam wallpaper remover, worked a treat.
Hello There
Quirky
Postby duddley » Mon Aug 03, 2009 3:18 pm
my old man used to have a carpet cleaning buisness and still has all the gear i may be able to help you out
i don't club seals..... only sandwiches
duddley
Postby pjay » Mon Aug 03, 2009 3:57 pm
Baking soda man. Or caustic soda. Its what I use indoors and on my car carpets. Has worked from everything from dog poo to wine to throw up. Never tried on milk though sorry
pjay
Postby sergei » Mon Aug 03, 2009 4:19 pm
pjay wrote:Baking soda man. Or caustic soda. Its what I use indoors and on my car carpets. Has worked from everything from dog poo to wine to throw up. Never tried on milk though sorry
careful with caustic soda, it will burn right through a lot of stuff, including your hands.
Postby Miss_S » Mon Aug 03, 2009 5:12 pm
Sponge the carpet with warm water and white vinegar, not too much vinegar as it can bleach. Maybe a tablespoon? Bi-carb soda (baking soda), sprinkle it on, leave it overnight then vacuum off. Should be all sweet, worked when my nephew vomited on my lounge suite and his mum didn't clean it up properly...
Miss_S
Postby Crampy » Mon Aug 03, 2009 5:27 pm
2LTR Rona wrote:One trick we use to use in retail when fridges were returned & stank was placing a bowl with vanilla essence in it inside the fridge over night or for a couple of days after cleaning them, works a treat to remove smells that have seeped in to it, might also work for you
Vanilla essence works a treat. Gets rid of the most nasty smells (read: rotten fish and chicken).
Crampy
Postby Miss_S » Mon Aug 03, 2009 5:28 pm
make sure it's real vanilla essence though, not imitation.
Miss_S
Postby Heylin » Tue Aug 04, 2009 3:09 pm
+1 on baking soda, problem with milk is it conatins casiene, once that bitch is dry its hard to make liquid again and pull out.
Sounds like the surface is clean and whatever has gone through to the foam \ underlay is smelling.
Heylin
Heylin
Postby HZRDIZ » Tue Aug 04, 2009 4:23 pm
The Shake & Vac has shown where the stain is so now i'm focusing on that area there. Will try the vanilla essence trick and vinegar/baking soda trick as well... Still smells citrusy fresh though :)
HZRDIZ
Postby Lurkin » Wed Aug 05, 2009 9:51 am
I had the rugdoctor prodcuts, sprayed the hell out of the area then went to BP and used their vaccy to get it out.
problem is how far its soaked through - I did this pretty much immediately.
failing that, get that section of carpet pulled up and soak it? - this is a untested guess. I had an MR2 back in the day that got vomit in it - gave up trying to remove the stench, tried multiple cleaning products without luck.....
perhaps the steam cleaning would be worth a shot?
Lurkin
