exhaust laws
exhaust laws
Postby tomtom » Tue Sep 08, 2009 8:46 pm
hi i have a 1uz soarer. i have been told that i can bring the exhausts out in front of my rear wheel but behind the front doors because its a coupe.. so im guesing as long as its nt to loud its legal??? does any1 know about this??
TRUENO gtz! AND 1UZ MANUAL SOARER!
tomtom
Postby flygt4 » Tue Sep 08, 2009 9:40 pm
I know of a supra that used to have quad side exhausts behind the doors with no legality issues. hard part is hiding the mufflers under the car as a conventional muffler looks crap and and probly won't fit out the sides.
flygt4
Postby Leon » Tue Sep 08, 2009 9:46 pm
Also every time you go into a driveway, you flatten the pipe sticking out under the sill.
Postby flygt4 » Tue Sep 08, 2009 10:35 pm
yeah I remember that happening on that particular vehicle. thats if you're lucky, if you're unlucky the pipe will smash up into your sill and crack/damage it.
although it sounded like nothing else on earth under full throttle, you could literally hear the air being displaced from the engine.
flygt4
Postby postfach » Tue Sep 08, 2009 10:50 pm
http://www.lvvta.org.nz/stdEngine&Drive ... rsions.pdf
An exhaust system fitted to a low volume vehicle must:
(a) be of a good design using materials suitable for the purpose; and
(b) terminate in a position where the outer end of the exhaust pipe is not directly underneath the passenger compartment; and
(c) in the case of an external exhaust system which extends beyond the outer longitudinal extremity of the vehicle or the outer sidewall of the tyres, the exhaust system must:
    (i) have a radius of no less than 3mm on any sections facing toward the front of the vehicle; and
    (ii) have any sections of exposed exhaust contactable from the front of the vehicle or adjacent to points of occupant entry and exit adequately heat-shielded.
If it meets the criteria then I see no reason why it shouldn't be allowed.
You should also read http://www.ltsa.govt.nz/certifiers/virm ... 1-v3a3.pdf
postfach
Postby Lloyd » Tue Sep 08, 2009 11:53 pm
As above, read the WoF stuff as its not the same as the LVV wording
Postby Timmo » Wed Sep 09, 2009 4:13 pm
I think youll find that the rear seats in a soarer are behind the forward most part of the rear wheels (i.e. a rear passengers head sits just forward of the 12 'o clock spot on the wheel)
Lightweight baby
1991 MX5 Supercharged
Timmo
Postby tomtom » Wed Sep 09, 2009 6:02 pm
mm could be in trouble on that 1
tomtom
Postby deaf_rattle » Wed Sep 09, 2009 6:36 pm
mmm
Postby Mr Revhead » Wed Sep 09, 2009 7:18 pm
^that's not legal
Postby deaf_rattle » Wed Sep 09, 2009 7:20 pm
it passed cert and gets wofs
why is it not legal?
Postby Mr Revhead » Wed Sep 09, 2009 7:28 pm
has a tail gate
therefore exhaust is exiting before the last opening to the passenger compartment.
or maybe you could fail it under the one where fumes must be directed away from passenger compartment, or the one where it says it can be failed for exiting on the l/h side of the vehicle.
Postby deaf_rattle » Wed Sep 09, 2009 7:31 pm
exits on both sides.
and looks like its directed away from passenger compartment to me.
and i dont think the hatch counts and passenger entry/exit?
Postby Mr Revhead » Wed Sep 09, 2009 7:37 pm
doesn't say exiting on both sides is ok, it says exiting on the l/h is not
Postby cat007 » Wed Sep 09, 2009 10:45 pm
I think it does as the 'boot' section isn't seperated from the main cabin.
Postby tomtom » Thu Sep 10, 2009 11:14 am
thats sick tho m8...8's all the way
tomtom
Postby cat007 » Thu Sep 10, 2009 11:16 am
tomtom wrote:thats sick tho m8...8's all the way
haha you're not wrong! Such an epic amazing car
Users browsing this forum: Google [Bot] and 21 guests
