Who has access to or a contact with a CNC milling machine?
Postby cat007 » Fri Sep 18, 2009 4:51 pm
Need to get my brake calipers done
I've be stuffed around enough and starting to run out of patience
I have an indesign layup with all the dimensions on - and could possibly ask a guy at work to make a cad drawing or similar if need be
In Auckland preferred but not required
Hunt
Postby GTCRSHR » Fri Sep 18, 2009 5:16 pm
you will need vector DWG file
vaughn@profilecutting.co.nz
Nothing to see here ...
GTCRSHR
