swapping head light for ae111 levin
Postby grantourismo » Fri Nov 06, 2009 6:34 pm
greeting to all
my younger brother is planning to buy a set of facelift model headlight which he plans to install on his pre facelift model ae 111 levin
would they work please let me know if you have experience over this
do the face lift model use hid or just conventional light bulbs ?
any info will help thanks alot guys
grantourismo
Postby Rick » Fri Nov 06, 2009 6:39 pm
Is your brother buying a facelift bumper aswell? facelift headlights are non HID but the plugs are different so that will need to be changed.
Postby grantourismo » Sun Nov 08, 2009 3:20 pm
Rick wrote:Is your brother buying a facelift bumper aswell? facelift headlights are non HID but the plugs are different so that will need to be changed.
so i do need face lift bumper for everything to work ?
the plugs ... you mean the plug that goes to the back of the headlight? :?:
grantourismo
Postby BZR4AGE » Sun Nov 08, 2009 4:01 pm
yes, prefacelift uses H4, and facelift uses H7 for low beam and HB1 for high beam, so you will need to re-wire it if you have the knowledge
BZR4AGE
