Boost Control with Power FC ST205
Postby ST205 GT4 NZ New Group A » Sat Nov 21, 2009 7:55 am
Thought that other people might be interested to know that you don't have to buy the seperate "boost control kit " for the power FC at $$$$.
I just used a MAC valve and connected it the factory boost control solenoid feeds and it works perfectly.
In effect all the boost control kit from apexi is, just a valve.
Turn it on in the power fc and set your four boost presets,
Postby Akane » Sat Nov 21, 2009 4:42 pm
Got any more info of this other valve you speak of?
I know there has been hack jobs of using other valves in place of the APEX'i one, but you still need a plug, and I *think* you need datalogit software to adjust the solenoid drive values?
Boost Control
Postby ST205 GT4 NZ New Group A » Sat Nov 21, 2009 6:27 pm
The valve I used was the one from my old profec boost controller.
Told by a mate that the valve is called a MAC valve.
Just quite surprised that instead of spending American $222 + or - on the " official boost control kit " I could just re use my old valve and that it works !
Of course I put a new plug on the valve and wire feeds.
Hey no expert but thought others would be interested to know that the "kit" is just a valve and wire, from the look of other boost control kits for other cars have a map sensor as part of the kit.
