Undecided on Brake Pads
Postby ch4ng » Tue Nov 09, 2010 8:10 pm
Hey guys I've just bought myself some big superstrut twinpot brakes for my bzg. They're all cleaned up, unsiezed and new caliper kits done
Which pads do you recommend? The car is mainly on the street but I plan to attend some track days next year
I would like to run Bendix Ultimates but they don't make them in a DB1352 :(
So it seems my options are
    Normal road pads
    Mintex 1166 (or another compound if they do it)
    TRD black
Especially keen on comments on the TRD pads
Cherrs
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby AE86less » Tue Nov 09, 2010 8:15 pm
Race Brakes
0800 Brakes
http://racebrakes.co.nz/
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby strx7 » Tue Nov 09, 2010 8:16 pm
what do you use it for?
Re: Undecided on Brake Pads
Postby Lloyd » Tue Nov 09, 2010 8:18 pm
ch4ng wrote: The car is mainly on the street but I plan to attend some track days next year
Postby metal_sean_head » Tue Nov 09, 2010 9:09 pm
EBC?
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby pureadrenalin » Tue Nov 09, 2010 9:27 pm
Endless CCX 8)
Duct tape is like the force. It has a light side, a dark side, and it holds the world together
pureadrenalin
Postby rx7guy » Tue Nov 09, 2010 9:45 pm
You should be able to get bendix ultimate compound put on existing backing plates
The torque band is wide and the road is narrow
rx7guy
Postby levinguy » Tue Nov 09, 2010 10:01 pm
genuine?
cheap and pretty good for the price.
if you cook them at the track upgrade then, if you don't you've saved yourself a couple hundred, if you even make it to the track.
levinguy
Postby Dell'Orto » Tue Nov 09, 2010 10:02 pm
TRW/Lucas pads are good for road and occasional track use.
Postby ch4ng » Tue Nov 09, 2010 10:08 pm
Rx7guy
Do you know where this can be done?
0800racebrakes do the same thing but I don't know if they can do that compound
I have sent them an email asking... Waiting to hear back
I could go the way of standard/genuine pads... How scary it it losing ya brakes in a Motorsport event?
Any comments on the Ted ones anyone?
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
ch4ng
Postby Akane » Tue Nov 09, 2010 10:29 pm
I has TRD black, which is compatible with AE111 calipers.
I haven't pushed it that hard to know if it fades or not, but a lot of dust.
Postby mjrstar » Tue Nov 09, 2010 11:35 pm
pureadrenalin wrote:Endless CCX 8)
this
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby Truenotch » Tue Nov 09, 2010 11:39 pm
rx7guy wrote:You should be able to get bendix ultimate compound put on existing backing plates
Can vouch for Bendix ultimate being a good street/track pad - and cheap.
You should be able to get them for the AE111 from BNT - slap them in and go hard. If they don't make a pad for the S/S AE111, get a similar one and shape it to suit on a bench grinder.
Truenotch
Postby 2jayzgte » Wed Nov 10, 2010 7:35 am
ch4ng wrote:Hey guys I've just bought myself some big superstrut twinpot brakes for my bzg. They're all cleaned up, unsiezed and new caliper kits done
    Normal road pads
    TRD black
Cherrs
I would'nt touch Mintex 1166s with a barge pole I've been doing track-days in my Supra for about 10 years and they are the only pad that has physically melted onto the rotor all the way back to the backing plate,like chunks of brake pad which caused me to go off the front straight only time its happend using those pads I also got from Racebrakes so I'm not a real big fan.
If you go the TRD route you'd be better off using the TRD Reds they have a higher temp rating than the Blacks at about 650 vs the about 450 for the Blacks.They are a good pad don't give the intial bite more of a smooth progressive feel through the pedal but work I'd rate those over the Mintex pads for sure and alot kinder on rotors.What sucks is they cost abit of coin so be prepared to pucker up.
The other option I'd suggest is stick with a set of pads for the road and get a track-day specific pad this is the route I've chosen and use Hawk HT-10s for the track.They give a really good intial bite when the pedal is pushed which is all good and you can modulate the pedal from there.Negative of them is there quite dusty and are really hard on rotors but I guess if you want the most out of your car theres always a trade-off.
Good luck theres boat loads of options out there and I hope this helps.
2jayzgte
Postby ch4ng » Wed Nov 10, 2010 7:36 am
Yea I thought about reshaping another pad
How safe is this? Has anyone fine it before?
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
ch4ng
Postby touge_ae101 » Wed Nov 10, 2010 9:23 am
Dell'Orto wrote:TRW/Lucas pads are good for road and occasional track use.
+1 these pads are an awesome i never get any fade on the track and they are good for the road too. and comparitively cheap!!
have done 30min track sessions without any brake fade braking very late...
touge_ae101
Postby Truenotch » Wed Nov 10, 2010 11:37 am
ch4ng wrote:Yea I thought about reshaping another pad
I've done it to a set of pads for ST185 calipers - they work well and are still going strong. You don't want to take too much meat off, so get something fairly similar to start with (the bendix book has drawings).
If you want a set of pads to do both well, the Hawk HP+ would be a way to go, but you'll spend about $290+gst on a pair. http://www.hawkperformance.com/performance/hpplus.php ... And they may not make them for your car.
If you're new to trackdays I wouldn't worry too much - just get out there and do it. Fit the best off-the-shelf pads you can find and go driving. It will help you find out what you need for track work before splashing out on a set of expensive pads.
2jayzgte wrote:I would'nt touch Mintex 1166s with a barge pole I've been doing track-days in my Supra for about 10 years and they are the only pad that has physically melted onto the rotor all the way back to the backing plate,like chunks of brake pad which caused me to go off the front straight only time its happend using those pads I also got from Racebrakes so I'm not a real big fan.
... I remember that day... An escort, prelude and me were 3 wide into Toyota, and all of a sudden a Supra comes flying through.... Weaves past us and ends up in the tyres - could have ended much worse!
Truenotch
Postby Chelles » Wed Nov 10, 2010 1:01 pm
2jayzgte wrote:I would'nt touch Mintex 1166s with a barge pole I've been doing track-days in my Supra for about 10 years and they are the only pad that has physically melted onto the rotor all the way back to the backing plate,like chunks of brake pad which caused me to go off the front straight only time its happend using those pads I also got from Racebrakes so I'm not a real big fan..
Where as I rate Mintex 1166 very highly for my Mitsi Mirage race car. My car is light, nimble and get around 170km down the straights at Manfeild and around 190ish km on the back straight of Taupo. They have been brilliant for the road and for the track. What you need to do is take into consideration your driving style and the weight of your car with your considerations.
A Supra is heavy (unlike your little BZG) with big power and asks a lot more from its braking systems. Also please please change [regularly] your brake fluid as that makes a huge difference to your braking abilities on the track. Think of your braking system as a whole not just the pad that hits the rotor... so many do this and find much fail when putting the car under a stressed track situation.
Happy researching. :)
'96 RS Mirage Race car... (and when I'm a good girl; EVO 1!!) 2014 Toyota Hilux - daily driver!!
Gone but not forgotten: Race car AE85.6 Levin, AE101 Trueno, 84 MR2 AW11, 94 MR2 SW20, SR coupe KE35, AE92 FXGT, AE91 FXZS...
Chelles
TS Original Member
Postby Dunny » Wed Nov 10, 2010 1:14 pm
I'm with 2jayzgte on the Mintex 1166 they are rubbish, quickest wearing track pad I had, couldn't handle the temps generated & cost a bomb, would never go there again.
I'm using Wilwood front and rear, heaps of compounds and are great performance and price. Have lasted ages. That's on a dedicated track car
You'd need to cut them for your application though
'81 KP61 uprighted 4k racecar (built by Rush Automotive)
'72 KP30 2 door
Dunny
Postby Truenotch » Wed Nov 10, 2010 1:58 pm
Where do you get the Wilwood pads from Dunny? I'm in the market for a set for the 86 at the moment.
I've also got a set of 1166 pads for my AW11. They've done a few trackdays and are starting to crack (they seem to be bad for that). They work well from cold and are a good autocross/club sprint pad but I wouldn't buy them again.
Truenotch
Users browsing this forum: No registered users and 22 guests
