Where do sw20s rust?
Postby Grrrrrrr! » Wed Dec 29, 2010 6:28 pm
Considering buying a manual NA SW20, just wondering where i should be checking for signs of the car cancer. Its got one patch thats a fairly easy fix (roof) but I'd like to know where to check to avoid getting a rust bucket.
Also, what are the other common problems with them... ie expensive things that stop car from running, or passing WOFs.
Thanks
Grrrrrrr!
Postby Al » Wed Dec 29, 2010 7:23 pm
Just check the oil regularly. The early 3sge ones have a habit of running big ends when people don't keep the oil full :lol:
Al
Postby Adamal » Wed Dec 29, 2010 8:08 pm
Al wrote:Just check the oil regularly. The early 3sge ones have a habit of running big ends when people don't keep the oil full :lol:
*Cough* What are you on about... *cough cough*
Can't say I've ever seen any major rust on SW's. Seen a bit of surface rust. Last one had a bit on the boot lid. My other one had a bit on the door.
One of the things I'd look for would be where the front sway bar mounts to the chassis. They tend to crack around there.
Here's a pic of mine after they tried to weld it up.
They eventually had to cut them out and weld new plates in. Has to be done by a certified welder and have an engineering report (or something, was a while back, can't remember the finer details).
Other than that, the early 3S's are hit or miss. They're either indestructible or already rooted. First SW was solid as a rock. Second drank oil like it was a 2 stroke.
EDIT: Alternators quite often go too. And they're fun to replace. Some say that they can be taken out of the bottom, but I dunno, maybe they were working on turbo ones. Exhaust gets in the way on N/A ones I've found. Have to take the alternator out of the bracket, then remove the bracket from the block (3 17mm bolts from memory) and then pull the alternator out the top. Would probably be easier with a hoist... Scratch that. EVERYTHING is easier with a hoist.
Postby MAC_HATER » Wed Dec 29, 2010 8:29 pm
3S-G(T)E's will pack up with the ferocity of an imploding star if you neglect the oil for any length of time - keep it clean and keep it full!
:D
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Postby al_feinted » Thu Dec 30, 2010 6:41 pm
If it has a rust hole in the roof have a real good look at areas underneath that as water is more llikely to have entered there and trickled down to other parts.
Project cars: 83 corona tt142, 83 corona mark2 gx61, 82 avante chaser gx61.
www.toycrazy.net
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1408
al_feinted
Postby KinLoud » Thu Dec 30, 2010 11:45 pm
Sorry, I couldn't resist a bit of location humour
Postby iOnic » Fri Dec 31, 2010 8:35 am
SW's don't really rust unless they've been hugely neglected. If the one you're looking at is rusty just walk away - there are plenty of others around, they're not exactly rare :lol: Common faults = 3S
Postby Al » Fri Dec 31, 2010 5:45 pm
iOnic wrote:Factory fitted immobiliser = 3S
Al
Postby 2fas4u » Sat Jan 01, 2011 9:49 pm
on my SW20 with targa top, sometimes the area where the glass seal is can rust as it's always exposed. The spare tyre bay at the front, under the plastic moulded shell of the spare tyre.
The only thing it ever failed wof on was the steering rack rubber boot. they are great fun cars, Don't give a sh1t if people say they are for gay guys...what a crock, if they actually cared to look it up, it's Mid Rear 2 seater not TWO MISTERS :? do make sure you check the cooling system as i've had a turbo version overheat and blew headgasket on me due to the fact the radiator is all the way at the front and the engine behind the drivers and passenger seat. Great drifter and fishtailers :twisted: The turbo's are a blast to drive, real pocket rocket!
2fas4u
Users browsing this forum: No registered users and 22 guests
