Portable Air Con unit in a vehicle questions
Postby MrOizo » Tue Jan 18, 2011 1:38 pm
Since reinstalling air con in my work wagon is going to be a mission, does anyone have any recommendations  of a portable unit like some people have in caravans?
Is there a 12v system?
I have looked at portable units that require 240v with 3kw - does a inverter need to match this rating?
Cheers.
MrOizo
Toyspeed Legend
Postby sark.inc » Tue Jan 18, 2011 3:28 pm
An inverter would need to be near double that, as the electric motor can draw up to twice it's operating power when starting. :)
p.s 3KW i assume it does not have a standard plug? also you would be drawing a LOT of power from the cars electrical system, around 210amps or so.
sark.inc
Postby MrOizo » Tue Jan 18, 2011 3:32 pm
Yeah i guess - we have a second charging circuit for batteries on the trailer - that has 2 x N200 sized deep cycle batteries on it.
What could i use as a AirCon system that didnt have a pump on the engine?
MrOizo
Toyspeed Legend
Postby MrOizo » Tue Jan 18, 2011 3:35 pm
Something like this would be ok i guess.
http://www.trademe.co.nz/Home-living/He ... 164163.htm
I have a inverter on board doing nothing which is 1000W or 2000W - cant remember. Getting a bigger shouldnt be a problem. Something that can run off it would be handy.
MrOizo
Toyspeed Legend
Postby sark.inc » Tue Jan 18, 2011 3:38 pm
is it a 24v or 12v system? if it's 24v system it would be around 100amp.
it's either a pump run directly off the engine, or indirectly through an electric motor afaik.
p.s you would need to know the power consumption of that unit first.
sark.inc
Postby MrOizo » Tue Jan 18, 2011 3:42 pm
It's a 12v system. An electric motor driving a pump would be good.
MrOizo
Toyspeed Legend
Postby pureadrenalin » Tue Jan 18, 2011 8:40 pm
Duct tape is like the force. It has a light side, a dark side, and it holds the world together
pureadrenalin
Postby Bling » Tue Jan 18, 2011 10:40 pm
Jebus :?
I imagine it's like a fridge in there though haha!
Postby MrOizo » Tue Jan 18, 2011 10:50 pm
Thats an option.
Better than sitting in 35+ deg heat. 97% humidity doesnt help either :?
MrOizo
Toyspeed Legend
Postby neo » Wed Jan 19, 2011 12:37 am
seems option 1 is to have a chillibin full of icewater and run that though a radiator of which you have air blowing across. Seems like a cheap work around
url doesnt link in the forum -- http://www.instructables.com/id/Portabl ... p-and-easy!
I'm thinking, have a chilli bin fill of ice water somewhere in the back, pump the chilled water to a radiator that has fans attached in the front of the cabin. When the ice melts, stop in at the servo for another bag :)
Or Option 2 you want to go to a truck wrecker and try to get an after market cab cooler
http://www.corunclima.com/product3_3.htm US Website, from what ive seen your looking around 1k
neo
Postby cat007 » Wed Jan 19, 2011 7:41 am
MrOizo wrote:Something like this would be ok i guess.
Correct me if I'm wrong, but aren't most 240v houses wired with 15amp fuses? 4000watt @ 240v = 16.6amps....which would pop the fuse every time you used it?
Postby Soiled » Wed Jan 19, 2011 11:43 am
Power outlets are normally 20A breakers, lights 10A, and AC is normally on it's own dedicated circuit so can be whatever it needs to be.
Soiled
Postby whynot » Wed Jan 19, 2011 5:37 pm
a heat pump/aircon that draws 4000w is a rather large unit. from what i remember most domestic units only draw around 700-1000w but you have to allow for the surge on start up
whynot
Postby matt dunn » Wed Jan 19, 2011 7:26 pm
Sounds like a shyte idea to me.
1000W is 1000w no matter the voltage.
So 1000w through a 240v inverter is
1000/240 4.16 amps,
cool,
but the inverter drawing from 12V
1000/12 is 83.3 amps.
So your going to need to fit another alternator to run it,
or a large battery for 10 mins of cooling.
Inverters to run anthing large are way to power hungry.
Postby h8wrxs » Wed Jan 19, 2011 10:29 pm
drive with the window open?
h8wrxs
Postby cat007 » Wed Jan 19, 2011 10:38 pm
Fixed haha
h8wrxs wrote:drive fast with the window open?
Postby MrOizo » Thu Jan 20, 2011 12:50 am
matt dunn wrote:So your going to need to fit another alternator to run it,
Not a major - already have another alternator fitted to power the trailer unit. Its the reason the compressor was removed - to fit another alternator.
I'll go and get a price from some places the next few days if i have time.
MrOizo
Toyspeed Legend
Postby MrOizo » Thu Jan 20, 2011 12:53 am
h8wrxs wrote:drive with the window open?
I need to drive and stop every 20m-100m and do testing which takes about 30-45 seconds. in that time things have got damn hot and unbearable.
So not very helpful...
MrOizo
Toyspeed Legend
Postby pureadrenalin » Thu Jan 20, 2011 11:37 am
I got a heater from these guys in Aussie for the race car.
They also make (distribute) stuff for air con systems that are put into kit cars.
http://speedyairspares.com.au/
pureadrenalin
Postby ee904age » Fri Jan 21, 2011 5:30 pm
That situation isnt going to be great with a/c either, seeing as the door will be opened every minute or so letting all the cool air back out. Plus, I dont know about you but I tend to get sick when walking in and out of aircon'd places all the time, something to do with sudden temp changes.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
