Dunny wrote:mylaps transponder, most if not all circuits in NZ should have the loop installed now
Adoom wrote:mylaps permanent transponder and performance box both seem to be ~$600
My wallet is hurting already...![]()
I saw one post that said the smartphone GPS is only 10Hz which is apparently too slow a refresh rate and can give you a 1 second discrepancy.
toymato wrote:I have a PBox (still learning to use) and also a manual timer that I find easy to use.
[/img]
toymato wrote:a manual timer that I find easy to use.
