exhaust tip install
exhaust tip install
Postby byza213 » Thu Mar 10, 2011 11:18 am
what prices should i be looking at ?
and wheres the best place (pricing) around auckland?
for my e30 wagon
scored one for 50 bucks
http://www.trademe.co.nz/Trade-Me-Motor ... 212274.htm
byza213
Postby touge_ae101 » Thu Mar 10, 2011 12:11 pm
local engineer (or if you have engineer friends) would weld it on for a box of beer most likely.
but other than than expect to pay $100-150. if you pay for it to be done, make sure they use a strap around the muffler to mount, don't let them weld to the stainless it will crack and break. and also if you wanted to do it 'properly', get a stainless flange welded onto the tip and a matching mild steel flange welded onto the existing exhaust.
this way you don't get into the welding stainless to m/s mess which most exhaust shops so happily. its not as strong, looks ugly and just yuck.
but up to you and whoever is doing the work really. adding flanges adds quite a bit of cost unless you plasma cut them yourself.
touge_ae101
Postby Babz » Fri Mar 11, 2011 7:06 am
See MR Muffler in Onehunga. He is cheap and does a great job.
1982 Carina TA63 (in the making)
1986 Corona TT141 SR20DE (Rear Ended and For Sale)
1998 Audi A3 1.8T (wifes daily driver)
2011 Mitsubishi Triton (Work Ute)
Babz
