loom wiring 4age to 3sgte
Postby 4ageboi » Tue Jan 17, 2012 11:27 pm
hello any one here knows any one that can do engine loom wiring and get car started..got a at210 carina came with a 4age blacktop..now put in a 3sgte gen 4 motor 4rm a gt-t caldina..any cheap hook ups??
wana run factory 3sgte ecu and wiring as i got that now
p.m thanks
PREVIOUS:1985 hiace,ee80 x2,ee80 liftback,ae82 fxgt,1st and last honda eva accord,ae92 sedan,ae92 levin (4age),st191 toyota corona,ae100 sedan x2,ae100 wagon x4,ce106 wagon convert (4age 20v),ae100 wagon (4afte),nissan sentra 1990,2zzge fielder,
CURRENT: ae101 GT corolla sedan,bz corolla wagon (4AGTE), corolla sprinter ae101 GT,isuzu elf truck. also new 2012 isuzu truck pending..
4ageboi
Re: loom wiring 4age to 3sgte
Postby sergei » Wed Jan 18, 2012 8:18 am
4ageboi wrote:hello any one here knows any one that can do engine loom wiring and get car started..got a at210 carina came with a 4age blacktop..now put in a 3sgte gen 4 motor 4rm a gt-t caldina..any cheap hook ups??
p.m thanks
Seeing that it is same/similar chassis, you might get away with plug-n-play loom from 215. Your fuse box and interior loom might accept the engine loom from 215. But doing a few rewires myself I haven't encountered a full plug-n-play: there will be some wires that need to be repinned/replugged.
Why not DIY?
Postby 4ageboi » Thu Jan 19, 2012 10:23 am
i could try it its just where could i find the wiring digram 4 3sgte and 4age inside wiring...or both even
4ageboi
Postby sergei » Thu Jan 19, 2012 11:02 am
4ageboi wrote:i could try it its just where could i find the wiring digram 4 3sgte and 4age inside wiring...or both even
you could use random Chilton/Haynes manual for same chassis Corona at your local library.
The wire colours will be ~99% same, while plug location and pin-out will be ~80-90% same. Most of that stuff that don't match could be traced easily.
