Tow Bar Design - Fiji Edition (Help please)
Postby MrOizo » Fri May 18, 2012 4:44 pm
I am over in Fiji at the moment and it seems tow bars don't exist here.
The road testing gear that i have is all trailer mounted so a towball is needed.
The Govt department here supplied me with a mid 90's Land Cruiser which had the following done:
I have told them I'm not happy with it because there are no provisions for safety chains or lighting - and i don't trust their welding.
What can be done to make this reliable? I have said to use some thick U shaped channel and weld to the tow hook.
I thought there could be a bolt through the hook on to the steel extension where the weld is as a back up but not sure.
If i had a idea what vehicle we'd have, i would have bought something like this with me:
MrOizo
Toyspeed Legend
Postby B_giB » Fri May 18, 2012 5:08 pm
Shouldnt this be in Funny Images? lol
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby MrOizo » Fri May 18, 2012 5:14 pm
B_giB wrote:Shouldnt this be in Funny Images? lol
Haha maybe - so should have got a pic of the actual work that was done! That was ROFL material!
MrOizo
Toyspeed Legend
Postby Bling » Fri May 18, 2012 5:18 pm
6mm x 50mm flat bar?? Not sure there are really any proper solutions as that has failed before it started. However, my only idea would be to put 4 bolts in to hold the bar / tow hook together. I'd also move the towball as close to the tow hook as possible.
6mm, lol
6mm!!!
edit: something like this
Actually, probably not possible, but bolt the towball through the tow hook bit
Postby Toby » Fri May 18, 2012 5:49 pm
Awesome :lol:
:D
Toby
Postby edwagon » Sat May 19, 2012 2:12 am
About the only thing that a 6mm drawbar is useful for is as a template for the 16mm plate that you should be using!
6mm has gotta be someone taking the piss!!
Oh and just a rule of thumb for bush spec welding jobs - a stick welder will generally produce stronger welds if the operator is not skilled, but they will most likely look awful - you can trust them within reason. Mig is easy to get looking neat, but hard to get good strength in heavier stuff- the nice neat bead will just sit on top... so be wary....
edwagon
Postby Mr Revhead » Sat May 19, 2012 10:15 am
If that wasn't so dodgy it'd be hilarious!
I don't think you have any choice but to tell them to make a proper bar.
Welding to the tow hook... oh dear!
Could unbolt the bumper from it's frame and use that as the basis for making a bar.
Or, smack them over the head with their 6mm plate and hang at the beach until your flight home
6mm plate! :lol:
Postby MrOizo » Sat May 19, 2012 10:57 am
Thanks for the comments guys. I'll see what they have to say / what they give me on Monday.
Mr Revhead wrote:... and hang at the beach until your flight home
I did that last month - 11 days on the company in Fiji and no work! :oops:
MrOizo
Toyspeed Legend
Postby Lloyd » Sat May 19, 2012 12:40 pm
Just weld another plate on the top of the hook and onto the bar, it'll be fine
