Hi guys,
thanks for the imput.
I am still running the distributor (much to my bane) I did put a different distributor cap on for better clearence of the intake.
I am pretty sure the Jzz is the same as the JA80 for supension, so should be the same like your supra Na-T.
It isnt the turbo that is actually hitting the tower(although if the engine moved alot it probably would), it is that the compressor out is close to the tower. The turbo is clocked towards the manifold as much as possible. If I cut a slight angle on a 90 degree joiner so I can get it right on the compressor out, then the silicon coupler is slightly compressed against the tower when the egine is at rest .
So, the best option is to get a 90 degree elbow welded on, but even if I do that the elow will still hit the tower when the engine torques.
So I thought that a torque damper would be a good idea, see how well it works and then get the elbow put on the turbo. Also, the downpipe and wastegate are hard plumbed into each other with no flexi, so I thought that having a torque damper might help reduce stress on them.
I tell you what, this has been a learning curve, I couldnt even use a ratchet properly when I started
I will take a photo of the problem.
Thanks Again
Edward
Science never sleeps...
RVR Turbo (idle)
