Grrrrrrr! wrote:I could make you a real carbon fibre panel if want Adrian.
2 layers of carbon either side of foam core. (2mm of solid carbon would be more than $200)
Will lay it up on glass so you get one good side and one rough side (good for gluing mounts and stuff to)
$80, and would be about two weeks before I get a chance to make it.
Let me know if you're keen.
Stott69 wrote:Ive just done a few trim peices in the car with the cheap stuff off trademe. Easy enough to do yourself, just make sure you have a clean work space.
matt dunn wrote:The local signwriter that does a lot of race car stuff had it.
we have also used it on other bits and peices on the MRS etc.
Grrrrrrr! wrote:Should be fine with foam core, but i can throw a couple of layers of glass behind the carbon if you want. (glass is cheap)
I'll keep it rectangular, its just easier for me.
