Car Trailer - Material for deck
Postby edwagon » Tue Apr 09, 2013 10:32 pm
I am nearly finished building another car trailer - internal deck size 4500x1900
I am stuck on what to make the deck out of - I usually use steel tread plate and weld it on but am looking at other options, partly because I am looking at having a full deck so its useful for carting other stuff.
I need to make a decision before it goes for galvanizing so I can cater for fixing whatever I end up using
Cross beams are 50x25 RHS on edge, with 525 between spans
I have looked at using 20mm T&G flooring ply, but will require extra support on the edges == weight and cost and lots extra work
I am leaning towards using boards like a truck deck, but have not had good luck finding suitable timber.
How thick would it need to be?
180x42mm T&G Retaining wall timber is well priced - kinda half joking but do I just use that? Anything wrong with it?
Anyone got any ideas?
edwagon
Postby touge_ae101 » Tue Apr 09, 2013 10:35 pm
decking timber always works well. give it a stain and it looks a million bucks + cheap as chips..
or you can get a grooved & stained ply (can't remember the name dammit) that looks really good on trailers and is grippy.
touge_ae101
Postby 85AW20v » Tue Apr 09, 2013 11:04 pm
Be aware that any solid timber like decking or T&G retaining wall decking will shrink as it dries whereas ply is a lot more stable and won't move. I'd still go with the treadplate welded on before you send it for galvanising.
See ya
Simon
85 MR2 20v
85AW20v
Postby wde_bdy » Tue Apr 09, 2013 11:10 pm
Weld treadplate on, add plywood down the middle if you need to carry stuff other than cars.
Callum
wde_bdy
Postby RobertC » Tue Apr 09, 2013 11:11 pm
how much support is currently there?
this looks nice and comes in 12mm, 18mm and 28mm.
its called brownwood ply
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby edwagon » Wed Apr 10, 2013 8:29 am
RobertC wrote:how much support is currently there?
Ladder frame 100x50 sides and 50x25 cross beams, 525 gap between each
The front and rear have a 60mm flatbar ledge for the deck to sit on.
There is no support between the beams on each side where it meets the sides, so if I use ply I'll have an edge hanging in midair, unless I continue the flatbar ledge around the whole frame - ugh
edwagon
Users browsing this forum: No registered users and 37 guests
