Hilux surf opinions WTD from dudes who know
Postby BlakeNZ » Mon Apr 15, 2013 6:39 pm
Hi. I am contemplating buying a Surf approx 92-97. I know to avoid the 2.4 litre diesel, so was looking at the 3 litre diesel(1KZ i believe), though some of these crack heads too. So buying an older vehicle like this, am i better to buy the 3 litre V6 (3VZ i think), or will it be extra thirsty?
I intend to do about 400km a week for about three months over winter(pull a trailer on occasion), then use will drop way for the rest of the year till winter again. I'm guessing less around 10,000km annually.
Or should i spend the extra money and buy a later (96-'97) 3RZ 2.7 litre petrol?
Is it worth holding out for a very rare manual, for the extra fuel economy?
any helpful views welcomed. thanks.
BlakeNZ
Postby Lloyd » Mon Apr 15, 2013 7:22 pm
3VZ is thirsty, and they do head gaskets every so often. The 1KZ engines crack heads also but you often can't predict when it'll be. The 2.4 diesels (2L) will usually do heads also.
Pick of the bunch is the 1KZ, they're a damn good engine... if you look after them. And keep on top of the coolant changes.
The 3RZ is good too, they don't give a lot of issues.
Don't hold out for a manual, they're a lot nicer as autos.
Postby Dell'Orto » Mon Apr 15, 2013 7:24 pm
Get a KZN***. Its a much better engine than the other options, and cylinder heads aren't too dear for them.
Postby blackmk3 » Mon Apr 15, 2013 8:16 pm
+1 for the 1KZ
Budget in a brand new radiator, toyota t-stat, and obviously good coolant
A intercooler will prolong the head cracking, especially with towing frequently
The intake temps get up there that's forsure
Mk3 MA70 Supra
blackmk3
Postby Boost_4_Life » Mon Apr 15, 2013 9:04 pm
i rock a 1kz in the supercustom. Mean engine for towing. But yea as long as you are pretty pedantic with maintaining the coolant etc it will be fine. I towed up the kaimais on Friday, went mint as!
I assume the surfs are the same in that they run a trans cooler pipe through the bottom of the radiator for the auto? Often a good idea to asshole this and put in a separate trans cooler. That way you ease up the loading on the engine cooling system by pumping less heat into the radiator
The rally beast
The rally beast again!
Boost_4_Life
Postby solitaire » Mon Apr 15, 2013 9:47 pm
the wife has a kzn185, awesome wagon
AE92, KZJ120, KDJ120
solitaire
Postby edwagon » Mon Apr 15, 2013 10:21 pm
The kzn185s (96+) are a much better truck than the kzn130 imho
The 1kzs are not noted for their fuel economy but waaay better than the v6, and do go well.
Not sure on the 2.7 petrol, would imagine a little light for towing but they are a tough engine and fairly gutsy in the 2wd 'lux
The diesels are hard to pick up cheap but they do resell well, so prob worth picking up a clean one and then at least having easy sale once you're finished
edwagon
Postby BlakeNZ » Tue Apr 16, 2013 11:40 am
thanks for the awesome valuable input guys. Does anyone know much about the 3.4 litre v6 petrol(5VZ) that comes in the 96 onwards Surfs? i've read it is less prone to head gaskets than the 3 litre 3VZ, and is more economical too. The only reason i would look at that in preference to a diesel(after reading the above posts) is because of price- they seem to be a reasonable margin cheaper. The later models also gives me ABS and airbags, compared to the earlier ones.
BlakeNZ
Postby solitaire » Tue Apr 16, 2013 12:05 pm
The 96 has airbag and cracking abs - only thing with the 1kz is service schedule is a killer and registration with ruc makes it rather expensive to run
solitaire
Postby Mr Revhead » Tue Apr 16, 2013 2:14 pm
KZN185 is far superior, it's closer to a Prado than a Hilux.
I doubt a petrol would be cheaper to run than Diesel. RUCs aren't that dear, 5c a kay is pretty cheap.
Personally I'd go a 1KZ no question. Just look for a good one and make the above mentioned mods.
I guess as you are looking at 130 models your budget won't stretch to a 185 or Prado? If it does they are a much better wagon.
Or you could get an Isuzu MU :P
Postby BlakeNZ » Tue Apr 16, 2013 4:08 pm
i can afford a petrol 185, but the more expensive diesel 185s are hard to justify with the lower annual distances i'd cover.
BlakeNZ
Postby Mr Revhead » Tue Apr 16, 2013 4:13 pm
Yeah true, for something thats ya main vehicle def go 185. But sounds like a 130 will suit ya. Plus parts a bit chepaer.
Postby fj40cruzapete » Tue Apr 16, 2013 6:49 pm
both the sales guys at work have 1kz one in a prado one in a surf both have done over 500k and still going strong
fj40cruzapete
Postby rollaholic » Tue Apr 16, 2013 7:36 pm
i too would only want a 1kz powered surf
Postby strx7 » Tue Apr 16, 2013 7:51 pm
whats your budget approx?
Postby wde_bdy » Tue Apr 16, 2013 8:28 pm
Last I looked, the actual tow ratings are completely shit for any decent usage.
Callum
wde_bdy
Postby BlakeNZ » Tue Apr 16, 2013 9:25 pm
not towing heavy stuff. one ton max i guess.
My budget is not limited as such, but getting a land cruiser could cost 15-20k, or a prado 12-15k, a kzn185 $11k, but a tidy 130 could do the job anywhere from 5500-$9000.
so i guess i'm looking to spend 6 or 7 grand, but would stretch a little more to get ABS and airbags.
Here is a high km, but cheap petrol v6 xxx185. Most of these tend to come in this slightly unmanly pale blue...
http://www.trademe.co.nz/motors/used-ca ... 203010.htm
BlakeNZ
Postby Quint » Wed Apr 17, 2013 3:32 pm
3L for the win. can get one in an ln130 for sub 5g. mines done a shit load of hard work (know prior owners) and it has no $&#$% to give.
has 400+ on the clock and still blows less smoke than my new 1kd
Quint
Postby BlakeNZ » Wed Apr 17, 2013 7:02 pm
by '3L' do you mean the the 3 litre v6 petrol or 3 litre 1KZ?
BlakeNZ
Postby Mr Revhead » Wed Apr 17, 2013 7:03 pm
Or the 3L 2.8 non turbo. I hope not, it's a good engine but too slooooow
Users browsing this forum: Google [Bot] and 25 guests
