Driveshaft loop installer in auckland
Postby steroidcontaskie » Sun Sep 01, 2013 3:02 pm
Hi all
I have had a go at installing some driveshaft loops and it looks like it is going to be hard for me to get the generic ones I have bought to fit, so am looking for someone that makes and installs driveshaft looks in Auckland, the closer to Otahuhu the better.
Anyone know of any place that would do this?
Edward
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Postby d1 mule » Sun Sep 01, 2013 7:29 pm
Good luck getting any change fom $300. Hoops are a c**t to do nicely. Make what you have fit.
d1 mule
Postby steroidcontaskie » Sun Sep 01, 2013 7:35 pm
I kind of figured it would be expensive, but I don't think I will do a good job myself. I can see the certifier being less than impressed with the quality of job I can do.
I just don't know where to go to get then installed.
RVR Turbo (idle)
steroidcontaskie
Postby CAMB01 » Tue Sep 03, 2013 1:18 am
I bought some of the generic hoops for my car and had a mate modify them to fit for me.
Unfortunately there isnt much room in the tunnel and the driveshaft smacks the top of the rear hoop on a hard launch :?
Front hoop:
Rear hoop:
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Nu-Del » Tue Sep 03, 2013 8:22 pm
Go see Keg at DKM, they are on the shore but do amazing work https://www.facebook.com/dkmfabrication?fref=ts
Nu-Del
Postby spoonza6 » Tue Sep 03, 2013 11:39 pm
Damian A1 Turbos
Did couple hoops on an altezza I took to him, reasonably priced supply n fit
spoonza6
Postby steroidcontaskie » Wed Sep 04, 2013 12:07 am
Cool,
Cheers guys I will give them a call.
Edward
RVR Turbo (idle)
steroidcontaskie
Postby steroidcontaskie » Fri Sep 06, 2013 10:41 am
Hi all
So, I have had a go at installing the generic dirveshaft loops I bought. I have got the holes drilled and the loops mocked in. However, they are very close to the driveshaft and I am a bit concerned that the driveshaft might hit them while I am driving.
Anyone got an idea of how much the 2jz driveshaft will move and hence how much clearance I will need?
Edward
RVR Turbo (idle)
steroidcontaskie
Postby JZCrazy » Sun Sep 08, 2013 5:34 pm
Ed, How much clearance do you have?
JZCrazy
Postby steroidcontaskie » Sun Sep 08, 2013 8:39 pm
It is pretty hard to measure it, but I would say 3mm.
But I figured out that wasn't going to be enough. Today I got under the car, gave the hanger bearing a good push up to see how much it moves .... and it easily hit the loop. So I moved the loop higher and it clears now, but is only attached with 2 m10 bolts, not 4, so might be a cert issue.
Might make a custom top loop that clears and has 4 bolts I can do up.
Edward
RVR Turbo (idle)
steroidcontaskie
