Corolla Belta 05 pinking (oh, btw it's a CVT)
Postby apollo » Tue Jan 21, 2014 4:23 pm
2005 Corolla Belta sedan 1300cc, 2SZ-FE, VVTi and CVT.
We just bought this car at 90,000km. It's imported, so no service history and to ensure the fluids are correct we're getting the transmission flushed and filled with "CVT Fluid Type TC", and the engine filled with 10/30.
We're not flash harrys anymore (I'm 64 and she's 72) and are obviously not looking for performance nor a status symbol. We wanted this model for fuel economy and assume that variable this-and-thats contribute to it, and that as long as we don't tow heavy vehicles and keep all the fluids clean the little oilways will not clog up and it might work as it should. Right?
The transmission controls are D, S and B (bottom) and I have some concerns about the engine pinking I hear coming at low revs. It's quite faint pinking (and I change to S or B to raise the revs) but wonder about it.
100kph in D, 2000 rpm, runs ok on the flat then with a slight load engine starts pinking.
Change to S, revs rise to 3000 rpm, and pinking's gone.
Am I right in guessing that pinking is going to be a 'feature' of this motor when it's running so slowly? It's been years since I've heard an engine pinking and then it was a more gutsy noise. This car does a slight tinkly-tinkle-tinkle with anything other than flat road, (50kph/1000rpm or 100kph/2000rpm). I'm wondered if the valve timing apparatus is operating at low revs to avoid pinking.
Or maybe the car's been running at low revs most of its life and now the carbon's built up around the plugs.
Does it sound like coke build-up? Should we ask the service people to check the plugs?
Any thoughts welcome.
Brian
apollo
Re: Corolla Belta 05 pinking (oh, btw it's a CVT)
Postby Alex B » Tue Jan 21, 2014 5:30 pm
What fuel do you run? Brand/91 95 etc
Postby apollo » Tue Jan 21, 2014 6:14 pm
Alex B wrote:What fuel do you run? Brand/91 95 etc
91 Mobil Gull or Shell.
apollo
Postby Shrike » Tue Jan 21, 2014 6:53 pm
Try running 95 and see if it makes a difference the 91 in nz is crap pretty sure there was another thread about this engine and it had issues with pinking due to running bad fuel
Why dream it when you can live it
Shrike
Postby GDII » Tue Jan 21, 2014 7:33 pm
If the engine is a 2NZ then it has a 10.5:1 compression ratio. Most engines close to or above 10:1 don't like 91. 95 is better. Plus it should improve your fuel economy further.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Boosted_162 » Tue Jan 21, 2014 7:46 pm
GDII wrote:If the engine is a 2NZ then it has a 10.5:1 compression ratio. Most engines close to or above 10:1 don't like 91. 95 is better. Plus it should improve your fuel economy further.
Mentioned in first post it's a 2SZFE, which is 11.0:1. So yes would definately benefit from higher octane!
Postby apollo » Tue Jan 21, 2014 8:44 pm
Thanks everyone.
I note that the handbook only mentions "unleaded" fuel. I'll try 95 octane.
apollo
Postby solitaire » Tue Jan 21, 2014 9:36 pm
apollo wrote:Thanks everyone.
I'm sure I'll be corrected by one of the guys if i'm wrong but the rule of thumb i go by is:
NZ New: 91 octane unless otherwise specified
Jap Import: 95 octane unless otherwise specified
Anything with a turbo: 98 octane unless otherwise specified, 95 is ok if you cant find 98.
AE92, KZJ120, KDJ120
solitaire
Postby RS13 » Wed Jan 22, 2014 8:08 pm
For that particular engine, both the vehicle data sheets I've found list 95 RON minimum, probably why you're getting detonation with 91. Change fuel and you should be sweet, plus you'll get a little more power out of it.
RS13
Postby Bling » Wed Jan 22, 2014 10:32 pm
If it's bad i'd probably be going for 98 just for peace of mind. Not that much extra per tank.
Postby apollo » Thu Jan 23, 2014 9:23 am
Well, well! It needs 95 petrol.
Much appreciated advice.
I looked and found possibly the same data sheet RS13 found, at
http://vehicledatasheets.com/toyota/yaris_(06-)/1.3_p/0/2sz-fe/page-1
Now to drain the petrol...
Brian
apollo
Postby solitaire » Thu Jan 23, 2014 9:27 am
How much is in it? If its half a tank maybe just fill it up with 98?
Not fun draining petrol...
solitaire
Postby MAC_HATER » Thu Jan 23, 2014 9:44 am
Would it be an option to brim the tank as it is with 95 or 98, or add an octane booster to whats there, and just using it? as draining the tank sounds a little bit excessive haha, and if a single tank of 91 was going to destroy the engine, every single Blacktop 4A-GE in the country would have expired by now hahaha
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Postby Alex B » Thu Jan 23, 2014 11:07 am
I wouldn't even bother, just get it below half or what ever and fill it with 95/98.
Postby RS13 » Thu Jan 23, 2014 2:41 pm
Alex B wrote:I wouldn't even bother, just get it below half or what ever and fill it with 95/98.
Yeah, just use it until empty then top up. Draining petrol is a PITA and moderately dangerous.
RS13
Postby Bling » Thu Jan 23, 2014 9:25 pm
Plus it's been running on 91 since you've owned it, a bit longer isn't going to make a difference.
Postby rollaholic » Fri Jan 24, 2014 6:42 am
but if you do decide to drain it, i have a good home for the 91 :P
Postby apollo » Thu Jan 30, 2014 3:14 pm
almost empty ...
apollo
Postby Bling » Thu Jan 30, 2014 7:16 pm
You'd be better off just filling it with 98, it will still end up close enough to 98 and will be better than running it on crap fuel till it's empty.
