Describe a battery?
Describe a battery?
Postby cat007 » Mon Feb 24, 2014 4:38 pm
Hey
How do you describe the orientation of a car battery? i.e. positive terminal on the top left? Is there a 'code' system?
Re: Describe a battery?
Postby Mr Revhead » Mon Feb 24, 2014 7:04 pm
They usually talk about it as if the terminals are closet to you
Postby holden_fan2005 » Tue Feb 25, 2014 12:23 am
I've always said front left of right, big or small post.
holden_fan2005
Postby Pelo » Tue Feb 25, 2014 9:17 am
When I worked at Repco*, the Exide range had a code system of sorts.
For example, a typical Corolla battery would be an N310LP. Look at the battery with the posts closest to you.
N = compact?
310 = size/model
L = left hand positive
P = pencil post
Whereas an N310 would have the positive on the right hand side, and thick posts.
*Ages ago and I may have forgotten, or this info may be useless in 2014
Pelo
