5 second Supra
5 second Supra
Postby Lith » Fri Mar 06, 2015 9:24 am
Just putting this out there as no one else has posted it yet, and it may be relevant to peoples interests :)
5.972 @ 240mph:
http://youtu.be/RTIXEuVAYVY
2007 Mazdaspeed Axela
Lith
Re: 5 second Supra
Postby 2jayzgte » Fri Mar 06, 2015 6:10 pm
They must be well and truely in that 2200 + HP range if not more now.
There getting in that doorslammer type time range that they run in aussie aren't they.
EKANOO you want to see sick car collection that dude has some really go fast cars.
2jayzgte
Re: 5 second Supra
Postby Dell'Orto » Fri Mar 06, 2015 7:42 pm
Truly amazing stuff, will be interesting to see how many are quick to follow into the 5's. I see their full body car did a 6.60 as well, crazy fast
Re: 5 second Supra
Postby Stu- » Sat Mar 07, 2015 9:17 am
Stock or billet block?
Project Thread
Stu-
Re: 5 second Supra
Postby 2jayzgte » Sun Mar 08, 2015 11:12 am
Stu- wrote:Stock or billet block?
Billet for sure no way thats a stock blocked JZ.
2jayzgte
Re: 5 second Supra
Postby Lith » Sun Mar 08, 2015 11:44 am
This is one place you are not going to have an issue with me sharing a different view point. It is an OEM 2JZGTE... you can't get a more reliable source than I heard that from short of checking it myself so it's a pretty safe bet it's right :)
Power level uncertain as its track tuned but going by fuel usage at full boost etc it's comfortably north of 2500hp and boost levels are nearer to 100psi than they are to 50. Testament to the strength of these blocks, and the quality of the work the EKanoo team are doing.
Lith
Re: 5 second Supra
Postby Flannelman » Sun Mar 08, 2015 7:28 pm
Stock blocks can be made stronger with the use of block filler and taking the head bolts all the way through the block and become part of the main caps for the crank.
If it was me building the beast, its what I would have done.
The Flannel, formally known as Affroman
Flannelman
formerly known as Affroman
