NA Drifter wrote:also evo 1,2,3 fetch good $$ as many peoples still like them etc. So you "might" even find evo 4 cheaper than the older models!?
bluemaumau wrote:look at the engines on 1s,2s,3s they are all mounted on the opposite side off the enigne bay to 4s, 5s, 6s ,7s, 8s, 9s
which means the gbox had to be flipped over to the other side, thus making the evo 4 a sort of test dummy
Loudtoy wrote:bluemaumau wrote:look at the engines on 1s,2s,3s they are all mounted on the opposite side off the enigne bay to 4s, 5s, 6s ,7s, 8s, 9s
You do know why they did that aye?? And the motor is turned 180 as well if you look closely oh wait actually if you just look at it you see that.
I'l even give you a hint was aimed at trying to stop the front end lifting under acceleration, jury is still out on if it worked as well as planned or notSo not really a crach test dummy for them as they had been doing transfer cases boxs etc for a long time before the evo 4, a transfer case is a transfer case and a box is a box, doesn't really make much difference which way the gears a spinning inside them. I haven't heard of to many people blowing 4 boxs/ ransfer cases to pieces maybe your mates are just animals. Side stepping the clutch at least once a week will destroy just about any box/transfer case eventually tho
Return to Palmerston North / Central North Island Region
