UPDATED: RESULTS TOYSPEED SPRINT RACE RD3
Postby slydesigns » Sat Apr 28, 2007 8:55 pm
Round 3
Race 1
1st Richard - Snoozin
2nd Dan - Lith
3rd Clint - Prymal
4th Jimmy - Loudtoy
5th Cole - Slightly_looney
6th Brad - Slightly_sykotic
7th Simon - Slydesigns
8th Hagan - Ep82gt
9th Ants - Ant555
10th Locklin - GX61MarkII
Race 2
1st Dan
2nd Richard
3rd Clint
4th Jimmy
5th Brad
6th Cole
7th Simon
8th Locklin
9th Ants
10th Hagan
Race 3
1st Jimmy
2nd Lith
3rd Clint
4th Simon
5th Cole
6th Ants
7th Locklin
8th Hagan
9th Brad
10th Richard
Overall Results For Round 3
1st Lith - 27pts
2nd Clint - 24pts
3rd Jimmy - 24pts
4th Richard - 20pts
5th Cole 17pts
6th Simon - 15pts
7th Brad - 13pts
8th Ants - 9pts
9th Locklin - 8pts
10th Hagan - 7pts
Sprint King
Dan - LITH
Crash King
Richard - SNOOZIN
Crowd Favorite
Hagan - EP82GT
Fastest Lap
Dan - LITH
18.65 seconds
18 SECOND CLUB FOR ROUND 3
Dan - LITH - 18.65
Jimmy - LOUDTOY - 18.75
Richard - SNOOZIN - 18.75
Simon - SLYDESIGNS - 18.92
Brad - SLIGHTLY_SYKOTIC - 18.93
07 SERIES 18 SECOND CLUB
(Best lap to date and when set)
Jimmy - LOUDTOY - 18.43 (Rd 2/Race 3)
Dan - LITH - 18. 57 (Rd 2 Race 3)
Richard - SNOOZIN - 18.72 (Rd 2/race 3)
Clint - PRYMAL - 18.76 (Rd2/Race 3)
Simon - SLYDESIGNS - 18.83 (Rd 2/Race 1)
Brad - SLIGHTLY_SYKOTIC - 18.93 (Rd 3/Race 1)
Championship Points Table going into Rd 4
1st Dan (LITH) - 79pts
2nd Clint (PRYMAL) - 74pts
3rd Jimmy (LOUDTOY) - 70pts
4th Richard (SNOOZIN) - 63pts
5th Simon (SLYDESIGNS) - 56pts
6th Cole (SLIGHTLY_LOONEY) - 49pts
7th Brad (SLIGTHLY_SYKOTIC) - 40pts
8th Anthony (ANTH_555) - 26pts
9th Locklin (GX61MARKII) - 16pts
10th Brett (DEVIOUSMR2) - 12pts
11th Hagan (EP82GT) - 7pts
slydesigns
Postby Lith » Sat Apr 28, 2007 8:57 pm
AWESOME!! Simon joins the 18s club, never picked up on that on the day - welcome and congrats! :) :)
We're up to 5 now....
Lith
Postby slydesigns » Sun Apr 29, 2007 12:36 am
There are 6 in the 18 Second Club
For this round only 5 made it.
And on countback I made it into the 18s in Round 2! Me and Clint missed it though
slydesigns
Postby Lith » Sun Apr 29, 2007 10:19 am
AH ok had wondered :) 6 all up in the 18s is even better...
Lith
Postby Loudtoy » Tue May 01, 2007 7:45 am
Haha brad came 1st and 9th race 3 :)
I still got the points for it tho :)
C you guys next round, shall we try not to bend any carts this time around?? They might start charging more if we do :twisted:
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby slydesigns » Tue May 01, 2007 8:45 pm
Looking at a couple of solutions to the Kart contact problems.
One solution is a staggered start similar to Superbikes and MotoGP.
Instead of Kart 1 and 2 next to each other, Kart 2 will be next to, but half a kart rearward of Kart 1.
Kart 3, behind Kart 1, will be half a Kart further back from its box.
Kart 4 will benext to, but half a kart further back from Kart 3, and so on down the line.
This should alleviate the truck and trailering of all the karts on the inside line at the start and reduce the need for the outside karts to "force a hole", instead allowing everyone to merge WITHOUT contact.
Solution 2: If a kart is over halfway down the inside of you that kart has "right of line". If you then hit because you turned in on it, your at fault and run the risk of a black flag for that race (not the round).
If the inside kart HASN'T made it halfway down the side of your kart and it hits you (you are the outside, leading kart) then the INSIDE kart driver is at fault and subject to the same rules.
Learn to cover your inside line and you'll not be disadvantaged by this rule. Wide is faster but now at a realworld cost. Way the pros and cons, make your choice, accept the consequences.
If your passing on the outside, you need to be over halfway PAST the inside kart to gain "Right of Line" and force the inside driver to back off.
If you hit before this point you, the outside driver are at fault.
If you hit AFTER reaching this point the inside driver is at fault.
Deliberately turning in on top of (or into) another kart once you reach this point just to exploit this rule is a fault and black flag material.
It will be (and already IS) obvious if your driving "offensively" as opposed to aggressively and you WILL be punished accordingly. Daytona builds the karts themselves so any breakages hurt them a little more personally than you'd expect. Also the get punished through work.
I'll put my hand up and say I HAVE been guilty of deliberate contact, especially on the start, and I'm not alone. We play at being racecar drivers, and some of us are pretty damn good at it too, lets not turn into stockcar drivers instead.
slydesigns
Postby Loudtoy » Tue May 01, 2007 8:59 pm
I like all of that except for perhaps the starting sequence. The only was i can see that carts on even grid spots won't be disadvantaged is by having either a rolling start with everyone line astern or the same line astern formation but standing still. I've be fortunate enough to only end up in an even grid position twice and only once at the front. Not particularly good and i'd say on average you'd be looking at loosing 2 places in the 1st corner.
Maybe a suggestion, sort of takes the interstingness factor out of the start but then there is usually a big tangle at the start of each heat.
TS Member sine 2001
Loudtoy
Postby slydesigns » Tue May 01, 2007 9:05 pm
The karts arent MEANT to be on even grid spots
Kart 2 OBVIOUSLY qualified faster than Kart 3 yet Kart 3 can truck trailer up the arse of kart 1 and block out Kart 2, disadvantaging that driver right off the start!
Kart 1 is still in front, kart 2 is still second
slydesigns
Postby Loudtoy » Tue May 01, 2007 10:30 pm
No you misunderstand i mean even grid spots as in positions 2, 4, 6, 8 and 10 maybe, Basicly anyone on the outside leading into turn 1 :)
TS Member sine 2001
Loudtoy
Postby TRDGT4 » Wed May 02, 2007 10:33 am
Well I think that you should all stop crying and race. Everyone is in the same boat (kart) just leave it on the track !!!!!!!!!!!!!
TRDGT4
Postby Snoozin » Wed May 02, 2007 11:17 am
Totally. Let's just get out there and fang/keep it clean.
Let your driving do the talking :)
Snoozin
Postby slydesigns » Thu May 03, 2007 9:44 am
ok, how about we try one more round without the babysitting rules and we see if commonsense prevails. However, the start does need work still.
slydesigns
Return to Palmerston North / Central North Island Region
