The Road and Track Spring Series - Manfeild Dec 21st
Postby Truenotch » Thu Dec 11, 2008 12:04 pm
The Road And Track Sprint Series - December 21st at Manfeild
Regs and entry forms for can be found below or on the website.
MotorsportManawatu website *CLICK*
Regs: http://www.motorsportmanawatu.org.nz/fi ... NTREGS.pdf
Entry form:
http://www.motorsportmanawatu.org.nz/fi ... TENTRY.pdf
Remember Discounted entry ($60) close Wednesday 17th December, On the Day entries are $70
(Note: only the completed entry form is needed for discounted entry, payment of $60 can still be made on the day if entry is in before the 17th)
The Road and Track Sprint Series is where you learn to hone your track skills in a safe environment with your car. You need no expensive equipment to become part of the series, and can be competitive due to the structure of the class breakdowns.
As for vehicles we recommend your daily road car for these events , which can also be used in the RS Cup Series for the duration of the Manfeild Winter Series.
Your road car needs only a fire extinguisher fitted, and be free of all things loose in the cabin. We recommend that you tape / insulate your battery positive terminal and ensure that it is securly mounted in the original position (otherwise it needs to be in accordance wwith MNZ rules, 4 x 6mm bolts minimum and inside a sealed box. Make sure you bolt the battery and not just the box!)
All series dates will be listed on the motorsport Manawatu website for 2009 so make sure you are at the best club sprint series around.
If you have any questions about whether you are able to enter, or queries on the regs then get in touch with Julian on the number below.
We also have a need for a group of people to run Timing on the day, we have a few lined up but the more help the better. If you are interested in helping this event run the please contact Myself through a PM or call Julian Hardy (mcc) on 06-3575349.
Can you please post this up in Events Brad?
Truenotch
Postby Dell'Orto » Thu Dec 11, 2008 5:26 pm
Done y0
Return to Palmerston North / Central North Island Region
