Modified: no
hahaha.
The rest
blocked windscreen washer(left)
discoloured power steering fluid.
oil seepage from steering
slight noise in operation of transmission(all Altezzas I've driven seem to have this)
Will offer this evening...
Modified: no
has a ticking noise,checked with toyota was surgested new solanoids needed not a big job and is still fine to drive.
MasCam wrote:Nice picture of the traction control off button
MasCam wrote:You'll be able to show that "Equipt" guy how to really thrash a car now.![]()
MasCam wrote:Oh. and when is the supercharger going on![]()
pyro_sniper2002 wrote:So you brought the car.....and now make sure the tune is sorted out. Your worse than a kid in a damn lolly shop.
barryogen wrote:The funny thing is when I pulled out of the guys driveway on the test drive, I had to turn it off as it wouldn't let me take off on the gravel.
MasCam wrote:The one I test drove a few years ago you had to turn it off even on the bitumen on some of dunedin's shitty roads on uphill corners, it just wouldn't let you pull away over poor tarmac.![]()
Best just to keep it off![]()
HRT wrote:Must be time for a meet then
barryogen wrote:Would probably put a low-ish boost turbo on it... keep the turbo small so response would be good, and boost available from 3300-3500 or around there, so that way cruise fuel consumption wouldn't be too badly effected.
