Why is the Time an Hour Out?? (Daylight Savings).
Before asking a question on the board you will find many answers here.
Postby BlakJak » Fri Oct 21, 2005 4:58 pm
This comes up every 6 months ;)
If you click on 'Profile' - aka edit your personal forum profile - you'll see a field near the bottom that defines 'Timezone'.
This is user-configurable as we don't know where in the world you're browsing from. (Ok, NZ is a fair assumption, but we have browsers from overseas too!)
This defaults to GMT + 12 in most circumstances.
When daylight savings happens, in order to get the time to display right you need to change this to GMT + 13.
Likewise when we undo daylight savings, you need to change this back.
You can choose to have it display GMT all the time; you can have it on NZ Standard Time all the time, or you can tweak it when we set our clocks back or forward. Your call.
BJ.
BlakJak
Return to FAQ - Frequently Asked Questions
