MRP 4age/7a Billet Steel Crank Girdle and Billet 4340 Crank Ladders.
Crank Girdle
- Billet EN10025 Structural Steel
- Electroplated Black
- Optional Longer ARP main studs - 4age ARP studs work without the washer.
- Lowers the sump down 7.5mm
- Works with 4age OEM windage tray and 4age Sump
- Does not work with 7afe sumps as ARP mains hit the 7a sump #5. Will fit if you make mods to the sump in this area.
- Dual sump pattern to fit 20v/16v and 7a blocks.
$499 incl GST without the longer ARP studs,
+$126.50 with Longer ARP main stud kit
For those not so serious we have our Main Cap Reinforcements
5 caps
4340 Billet Steel
Nitrided
Full radius on the top side to relief any stress
Fits with 4age ARP Main studs
$160 incl GST
