Oil Filter/cooler Sandwich plate with Thermostat In-Built
Postby Bazda » Tue Mar 05, 2013 9:18 pm
MRP Oil Filter Thermostatic Sandwich plate
Sick of buying those oil cooler relocation kits with no oil thermostat?
Here is our solution.
- Thermostat Opening Temp: 80C
- Ports: 2x 1/8" NPT holes for oil pressure and oil temp sensors
- 2x block adapters 3/4"-16 unf & M20x1.5 to suit popular models
- 30mm thick
- Billet 6061 CNC aluminium
- Oil out fittings -10AN
- Ideal for getting oil up to temp before it passes through the cooler
- Can be used with oil filter relocation adapters
If you want to search what thread your car has look here:
https://www.hrpworld.com/client_imag...der/1062_1.pdf
$175 incl GST & shipping for TS members.
How it works, I will try explain it simply.
- Oil from the engine going into the filter has 2 paths to go. 1. To the oil filter, 2. To the oil cooler.
- The oil will not pass through the cooler back to this block when the thermostat is cold (closed), the engine will keep pressure in the oil cooler and lines when the thermostat is closed and oil will pass through the filter as normal while the oil temp increases.
- Once the oil approaches 80C the thermostat will slowly open allowing a smooth transition where it will slowly open the other oil cooler port up to allow the cooled oil to flow back into the filter block which goes up into the oil filter.
- The other port which oil flows through when cold will slowly get blocked off as the thermostat approaches 80C
- So at all times there will be oil flowing to the engine.
Postby Stott69 » Tue Mar 05, 2013 9:55 pm
Engine specific?
Stott69
Postby Bazda » Tue Mar 05, 2013 10:03 pm
Stott69 wrote:Engine specific?
Toyotas are 3/4"-16
But a full list can be seen here
https://www.hrpworld.com/client_images/ ... 1062_1.pdf
Note our adapter is only for 3/4"-16 or M20.
We can how ever make new adapters on request.
Postby Stealer Of Souls » Thu Mar 07, 2013 10:23 am
If I just wanted the temp and pressure ports (oil cooler = future upgrade still to come) can you "plug" the ports that should go to the cooler?
'86 AE85.5 Levin
Stealer Of Souls
Postby Bazda » Thu Mar 07, 2013 10:38 am
Stealer Of Souls wrote:If I just wanted the temp and pressure ports (oil cooler = future upgrade still to come) can you "plug" the ports that should go to the cooler?
You would need to loop the ports for oil cooler.
If you blocked them it would stop oil flow when thermo opens.
But you can take out the piston for the thermo, and then just block all the ports and will work just fine :)
Postby Bazda » Thu Jul 25, 2013 4:32 pm
IN stock
Return to Toyspeed Sponsors
