Extreme Clutch Kits - Street to Race
Postby Bazda » Thu Nov 13, 2014 1:50 pm
We can now offer oem fitment Extreme clutch kits.
Normally we build Twinplate Tilton clutch kits to suit anything, but we get the few guys who are just after a mild upgrade or a replacement clutch.
http://www.xtremeclutch.com.au/en/
Example pricing - Stage 1 kit HD 4age 212mm $395+gst
http://www.xtremeclutch.com.au/en/produ ... ch/stage-1
The stage 1 clutch kit uses an upgraded pressure plate with increased clamping pressure, combined with an organic friction disc. Stage 1 delivers substantial increases in performance and power holding capability whilst retaining near factory type driveability, and is designed primarily for high performance road going vehicles.
http://www.xtremeclutch.com.au/en/produ ... ch/stage-2
The stage two clutch uses an upgraded pressure plate combined with a ceramic friction disc in either sprung or cushioned configurations. The stage two clutch range is designed for road and track going vehicles that require a higher torque capacity and temperature tolerance, and faster engagement. Clutch engagement is more aggressive than stage 1, so it is not recommended for daily driven vehicles.
Return to Toyspeed Sponsors
